thunderblade50
Message 1 of 16
I keep getting connection drops and lag spikes
So whenever im playing games, and using discord or teamspeak i keep getting these random ping spikes, also my download speed peak is about 2 MB/S and my upload is 0.75 MB/S i would also like to understand why this is low, if i need to call customer service i would but for now want to see if i can do anything on my end
15 REPLIES 15
Message 2 of 16
Re: I keep getting connection drops and lag spikes
Hi Welcome to the community forums
Have you tried the quiet line test dial 17070 option 2 you should hear no noise if you can hear noise then it needs reporting to BT faults on 151 with no mention of broadband
in the call are you connected to the test socket using a new filter
if using a hub 4 locate these lines located in the hub logs
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
The stats for the Home Hub 6 can be found on the Information page from http://192.168.1.254 then Advanced Settings -> Technical Log.
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
thunderblade50
Message 3 of 16
Hey ive done the quiet line test but cant seem to find it in my hub logs, my hub is bt home hub 4 also, hope this helps
Message 4 of 16
use the WAN pull down you should find them tjere
thunderblade50
Message 5 of 16
thunderblade50
Message 6 of 16
Can i get a response back quicker pls, cause this only got worse during the start of the bank holidays, and its really driving me mad, if it does get resolved soon i might as well switch providers
Message 7 of 16
This is a customer to customer self help forum posts made here do not go to BT although the forum is moderated by BT not every post is read you get replies as and when people read you post and have anything to post that may help you
Message 8 of 16
Can you use this speed tester then carry out the further diagnostics test and post back a screen shot of all the results including your IP profile for up and down.
This test must be done with a wired connection.
http://speedtest.btwholesale.com/
once you have posted the information asked for then the community members can help you
Message 9 of 16
are you using a wired or wireless connection??
can you also run a tracert to BC.co.uk and post that result back
thunderblade50
Message 10 of 16
Well im using a wifi extender but my computer is connected to it wiredcmd_2017-08-29_18-01-26.pngchrome_2017-08-29_17-58-48.png
