pagsmacd
Newbie
Message 1 of 16
IP Profile is set at less than the 'Max Achievable speed'
Hi,
I've moved to a rural area and the BB speed is not up to much. However, running the BT Wholesale speed test shows that we have currently 2.8MB~ and an IP Profile of 3MB, but that the line has a max achievable of 7.15MB. I work from home and 2.8MB isn't always enough to allow me to join international video calls/presentations so having closer to 7MB would be a Godsend.
Does the IP Profile cap the max speed and can I do anything abut that with them?
15 REPLIES 15
Boudges
Message 2 of 16
Re: IP Profile is set at less than the 'Max Achievable speed'
the 7.15mbps is just telling you that you are on adsl max and that 7.15 is the max speed you can achieve on adsl max. You speed 2.8 is acceptable for your ip profile
If you liked a post, please click on the 'Ratings star' on the left hand side of the post.
Message 3 of 16
Hi Welcome to the community forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
if using a hub 4 locate these lines located in the hub logs
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Message 4 of 16
enter your phone number and post results  remember to delete number
https://www.btwholesale.com/includes/adsl/main.html
this will show estimates of what is available to you
pagsmacd
Newbie
Message 5 of 16
I have a home hub 5, where do I look for the ADSL stats? Can't obviously see it when I log in
Message 6 of 16
tye troubleshooting then helpdesk
pagsmacd
Newbie
Message 7 of 16
5. DSL uptime:0 days, 02:19:38
6. Data rate:448 / 3776
7. Maximum data rate:1040 / 3968
8. Noise margin:19.0 / 11.2
9. Line attenuation:31.5 / 53.0
10. Signal attenuation:31.5 / 51.9
Message 8 of 16
can you run the dslchecker and post results please
your stats show now margin high at 11.2db as normal about 6db  conenction time only 2hrs was that manual reset?
pagsmacd
Newbie
Message 9 of 16
Only 2 hours as I was trying another socet. We transfered our BB to the current number in November. How do I runthe dslchecker?
Message 10 of 16
just click on the link I posted earlier and enter your phone number
