Message 11 of 28
Re: IP Profile issues
Can you post the connection stats from the hub?
Taylor1892
Message 12 of 28
Hi @Webby
I don't use the BT equipment - I only usually plug it in to get those stats.
Cheers,
CT
Message 13 of 28
Can't you get the stats from your current router?
Taylor1892
Message 14 of 28
Hi @Webby
I can't....I will try get onto the modem and get it.
My sync speed seems to have increased when I tested in my work:
For your connection, the acceptable range of speeds is 0.05 Mbps-0.25 Mbps.
 Additional Information:
 Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 0.14 Mbps
Message 15 of 28
just be patient and your speed will increase automatically it takes 3/5 days of stable connection
Taylor1892
Message 16 of 28
I try to be but I don't pay to be patient every 4-6 weeks when I've had it fixed in hours before 🙂
Taylor1892
Message 17 of 28
Test Result
 Your DSL Connection Rate :7.58 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
The sync speed has now dropped to 7.58 mbps. I will contact BT India.
Message 18 of 28
Have you tried the quiet line test dial 17070 option 2 you should hear no noise if you can hear noise then it needs reporting to BT faults on 151 with no mention of broadband in the call
There is no point in resetting the IP Profile if the connection is unstable as it will just drop again as you have already found out
Taylor1892
Message 19 of 28
No noise on the line.
Day 3 of having an ip profile of 0.14mbps.
How many more days?
I haven't reset or touched anything.
Will contact BT India tomorrow night if not resolved.
I've had this EXACT problem fixed in hours, not 10 days.
What's the minimum speed I should receive until I am due a claim or official complaint?
Appreciate the help all.
CT
Message 20 of 28
the normal time is 3/5 days you need to check your routers connection time as any disconnection takes the time back to the start again
