alexc
Message 1 of 17
IP Profile suddenly 0.5Mbps
Hi - I've tried to piece this together from the forums, can someone verify?
Background:
I woke up today to find my connection 90% slower than usual. I Webchatted with someone from BT who didn't have anything useful to give me, other than a link to the BT speed test. After they were unable to help, I pushed another button on the speed test site which revealled that while my connection was at 8Mbps, my IP Profile was 0.5.
Is this right:
For some reason, my line has shown poor connection reliability so has been bumped down to the miniumum speed possible?
This will naturally remedy in a period of time?
I should leave my router on and resist the temptation to reset, otherwise it will never improve?
Openreach are the perfect storm of unaccountable and incompetant?
You can ignore the last one, I already know that's correct.
Ty 🙂
16 REPLIES 16
Message 2 of 17
Re: IP Profile suddenly 0.5Mbps
if your profile is down at 0.5mb then your router has dropped connection at least once and when it reconnected the down speed was <832kbps resulting in your low 0.5mb profile
if you maintain connection for 3/5 days with no resets or drops then if you have max 8128kbps connection speed then your profile should recover to 7.15mb.
try quiet line test  dial 17070 option 2  should be quiet and best with corded phone
are you using the test socket to eliminate your internal wiring from causing the drops in conenction?
alexc
Message 3 of 17
3-5 days? **bleep**, that's pretty painful.
The line test sounds ok, and the connection seems same as ever.
I'll just play the waiting game...
https://www.youtube.com/watch?v=4mDcZGRKQ_M
alexc
Message 4 of 17
Spoiler
It bleeped 'D4mn' ??
Message 5 of 17
LOL
alexc
Message 6 of 17
Just had a call from tier 2 support (I figured out the IP Profile thing between talking to T1 and T2).
She claimed to have reset the IP Profile and that the result should have been immediate (it wasn't)
Have I just reset my 3-5 day counter?
Message 7 of 17
has your router dropped conenction - can you post adsl stats from your router?
if your router has dropped conenction and profile not chnaged then yes timescale starts again
alexc
Message 8 of 17
She told me to restart the router..
I know..
You've got to assume that the techies being paid to be techies know what they're talking about.
Next time I'll lie.
alexc
Message 9 of 17
I've never seen it connect below this. I'm CERTAIN they've been tinkering with something outside the house.. 2.5 years of perfect connection, then somehow it drops to 0.5Mbps. And they've delayed the fibre roll-out to the village. Coincidence?
WANpppoa7186088533048712580900:50:41
LAN110M/100M8944676213026538577500:51:14
LAN210M/100M00:51:11
LAN310M/100M00:49:18
LAN4Link Down--
WLAN--------------
ADSL LinkDownstreamUpstream
Connection Speed8128 kbps448 kbps
Line Attenuation12.0 db6.0 db
Noise Margin11.8 db30.0 db
DownStream Connection Speed8128 kbps
UpStream Connection Speed
448 kbps
Message 10 of 17
sorry can your run btspeedtster diagnostic test please
btspeedtester
