Message 51 of 57
Re: IS MY SPEED LOOKING OK
jonnyblue5 wrote:
you know what keith its a faceplate latest one that dont need filters, but in living room theres a extension socket on wall were sky plugs in no longer contracted now so unplugged it and my connection now stable
I am wondering if that "extension" has been wired correctly, it should be connected to the back of the removable front section, or plugged in the front of the master socket.
I have seen cases where there was an old terminal block where the line came in, and people had added a DIY extension to that terminal block, which they are not allowed to do, as its before the master socket.
Forumhelp (Private website) Lots of additional information and help.
You will need to be connected to your home BT Broadband connection to view it, or any links to it that I post on this forum.
jonnyblue5
Message 52 of 57
just done a namsco speed test and getting 7.5 meg never had that, and 32 second ping speed used to be 60
jonnyblue5
Message 53 of 57
think your right keith it does go to the old terminal block
Message 54 of 57
That extension or Sky box is wired wrong somewhere I would guess.
jonnyblue5
Message 55 of 57
no worris will leave it unplugged now.
Message 56 of 57
surely if sky had been connected to the phone socket without a filter and wired incorrectly then it would drop connection when sky connect to box which didn't happen as original stats shows 15days connected
still main thing is connection now seems better
Message 57 of 57
That would explain it, and the errors.
Really you should disconnect that extension wiring if it does go back to an old block, as its very wrong to do it that way.
If you can remove it totally at the "block" end, then it should make things even better, and would bring the installation back to the way it should be. As the wiring "spur", is going to upset the broadband.
If you still need an extension, you are allowed to connect it to the wiring on the back of the filtered faceplate.
