Draekrio
Message 1 of 14
Improvable upload speed?
I've always had slow speeds because of my rural location, but recently I've been looking at my package information in my profile and on automatically detected available packages and both sources claim that I should be capable of an upload speed of 1 Mbit, and yet ever since starting my current service my upload speed has always been stuck at exactly 448Kbit and not a single bit lower or higher.
Is it possible that There is some kind of hard limit in place on my broadband profile that could be removed or even simply increased?
13 REPLIES 13
Message 2 of 14
Re: Improvable upload speed?
Post hub stat
Enter phone number and post results   Remember delete number
http://www.dslchecker.bt.com/
Moderator
Moderator
Message 3 of 14
@imjolly wrote:
Post hub stat
Hi @Draekrio,
Welcome to the Community.
Could you post the information that @imjolly has asked for so that we can see if we can do anything to improve your speeds?
Matt
Draekrio
Message 4 of 14
Here we go, I apologise for the delayed reply. I understand that because of my location very little can likely be done, but I would take what little I could get.
Draekrio
Message 5 of 14
I'm sorry for the double post to bump this up but it has been three weeks since the last response on the thread. additionally here is my package information both on my account and on the available deals page both claiming I am capable of 1mb upload speeds.
Message 6 of 14
from what you have posted you are on adslmax with up speed of 448kbps fixed. You could upgrade to adsl2 which may not improve your down speed but would increase your down speed by 80/100%.  The mods may be able to help. Post back if you want to try upgrade
Draekrio
Message 7 of 14
I'm very much interested if it could improve my speeds in either direction. I'm already fully away that the service I can receive is reduced by my location, but if i'm getting even less than what is available to me I'd love to see that fixed.
Message 8 of 14
Can  you post stats from your hub/router
any line noise. Dial 17070 option 2 should be silent and best with corded phone
are you using test socket with filter to see if that helps
Draekrio
Message 9 of 14
I am using a test socket and filter setup, there is no noise that I can detect on the test. and my router stats are as follows.
doing the quiet test appeared to have cut out my internet for the duration.
Message 10 of 14
Obviously you should not drop connection when using filter in test socket. Have you tried a new filter?  Do you have any unfiltered extension sockets or extension sockets with dial tone while you are connected to test socket?
