Message 21 of 25
Re: Incredibly poor upload speed
If the bellwire is connected to terminal 3 then remove it from all sockets - only connection required are on 2 & 5
Zacg99
Message 22 of 25
What if theres a orange wire in term 3 and a orange/white striped wire in term 4, do I remove them both?
Zacg99
Message 23 of 25
Ok. Removed the wires. ADSL stats: (download is lower :L)
PortStatusTxPktsRxPktsCollisionsTx B/sRx B/sUp Time
WANpppoa148561554006496858200:25:14
LAN110M/100M44598313002169016479251814 days 18:23:39
LAN2Link Down--
LAN3Link Down--
LAN4Link Down--
WLAN300M109000677686264030441652 days 15:25:32
ADSL LinkDownstreamUpstream
Connection Speed5760 kbps448 kbps
Line Attenuation36.0 db16.0 db
Noise Margin6.3 db23.0 db
Zacg99
Message 24 of 25
Noise margin increased on download :L
Message 25 of 25
should be able to remove both and only normally connected are terminals 2 & 5
