Railwayman
Message 1 of 4
Interleaving or Fast
Hello
After some advice, have no complaints regarding speed or connection, as I am only 200 metres from my exchange both are at max. My question is as both myself and my son are gamers (we play FPS games where ping is king) would having fast path reduce my ping and to what extent?
Stats below
Product name:Smart Hub
Serial number:+088044+1644005080
Firmware version:v0.09.03.07171-BT
Firmware updated:unknown
Board version:01
DSL uptime:9 days,13 Hours30 Mins03 Secs
Data rate:1.087 Mbps / 20.969 Mbps
Maximum data rate:1.080 Mbps / 21.152 Mbps
Noise margin:6.3 / 3.3
Line attenuation:4.3 / 9.4
Signal attenuation:4.2 / 8.2
VPI/VCI:0/38
Modulation:G.992.5(ADSL2+)
Latency type:Interleaved
Data sent / received:4.2 GB / 77.1 GB
Broadband username:bthomehub@btbroadband.com
BT Wi-fi:Activated
2.4 GHz wireless network name:BTHub6-6757
2.4 GHz wireless channel:Automatic (Smart Wireless)
5 GHz wireless network name:BTHub6-6757-5
5 GHz wireless channel:Automatic (Smart Wireless)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:Default
MAC address:E4:3E:D7:C5:6B:2C
Software variant:-
Boot loader: 0.1.6-BT (Fri Sep 9 10:05:09 2016)
Also am I right in thinking there is a small margin to inprove my upload speed.
Any advice welcome.
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Interleaving or Fast
Hi @Railwayman and welcome.
It’s possible switching to fastpath will improve the ping time but it can also have a negative affect on stability. There wouldn’t be anything we could do about the upload speeds but if you want to switch to fastpath drop me over an email with your details and I’ll check if it’s possible on your line. You’ll get the contact the moderators link in my profile.
Cheers
David
Railwayman
Message 3 of 4
Hello David
Thanks for prompt reply, would not want to spoil a great connection so after some thought will keep it as is.
Once again thanks for your advice
Gary
Moderator
Moderator
Message 4 of 4
No problem @Railwayman. If you have any other problems post back and we'll be happy to help.
Cheers
David
