Joshspurs
Message 1 of 5
Internet Connection Dropout/ Daily - using a hub (port 1 issues)
Been a BT customer since April. I've had a BT engineer inspect my setup and there's nothing wrong. telephone line sound is perfectly clear.
I have a hub connected to the ethernet port 1, and every day, at least once a day, if not more. my internet drops on the hub.(the hub acts as a wirless booster and i have my pc connected via an ethernet cable to this hub) i beleive i have setup my hub correctly turned off DHCP and so on - as it's worked plenty of times without any interruption. my event log has a lot of activity but i have no idea what it means. wire lan Port 1 seems to go up and down a lot.  sometimes the internet will go off when im not on it, sometimes it's just the wireless. To fix it, sometimes all i need to do is reboot the hub, or take out the ethernet cable and replug it back in.
i never had this problem before with previous serivce provider. i am going to be forced to change provider because this constant interruption isn't great when other people share you're internet and your wifi keeps turning off.
any help greatly appreciated.
4 REPLIES 4
Moderator
Moderator
Message 2 of 5
Re: Internet Connection Dropout/ Daily - using a hub (port 1 issues)
Hi @Joshspurs and thanks for posting.
Which hub do you have? Do the lights change when the connection drops? Can you post the event logs so we can take a look?
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
Joshspurs
Message 3 of 5
I have a home hub 5 and I have an ethernet cable in port one which goes to my study, connected to a tp link router acting as a repeater. Sometimes when I wake up in the morning or when I'm back from work, My tp link router loses Internet and to fix it all I need to do usually is unplug the ethernet cable and replug it. Also if it does lose internet, if I plug the cable directly into my pc, the Internet works. The problem is is I'm not around when it goes offline so I don't know what part of the event log to pass on.
The bt home hub Internet works fine no red lights from what I see.
Moderator
Moderator
Message 4 of 5
Thanks for posting @Joshspurs.
From what you've described it sounds like a problem with the TP Link. Can you try connecting directly to the hub and check if there are any drops?
Cheers
David
Kudos”Kudos”
Joshspurs
Message 5 of 5
Well this is the thing, the second router will randomly lose it's internet until i do something.
yesterday i replaced the tp link router with a business hub 5.  it worked beautifully until i got home tonight. same thing internet offline on secound router ONLY. take ethernet cable out of the second router, plug it into my PC, and it works, as i type right now. below is the event log for the main Internet Router. the main router works fine! it might have droppouts causing this problem? I fixed my pc to ip 192.168.1.10 -  also when i asked my pc for troubleshooting help when the pc was plugged into the second router it said 'could not find default gateway'
18:21:16, 13 Jan.(503492.660000) Admin login successful by 192.168.1.10 on HTTP
18:21:06, 13 Jan.(503482.890000) Admin login FAILED by 192.168.1.10 on HTTP
18:20:43, 13 Jan.(503459.850000) New GUI session from IP 192.168.1.10
18:20:39, 13 Jan.(503455.660000) Device disconnected: Hostname: AdriennesiPhone IP: 192.168.1.79 MAC: 88:63:df:70:3a:92
18:20:39, 13 Jan.(503455.660000) Device disconnected: Hostname: android-​f00ef7681ff2988a IP: 192.168.1.64 MAC: 64:bc:0c:69:cc:41
18:20:38, 13 Jan.ath00: STA 64:bc:0c:69:cc:41 IEEE 802.11: Client disassociated
18:20:19, 13 Jan.(503436.180000) Wire Lan Port 1 up
18:19:54, 13 Jan.(503410.900000) Lease for IP 192.168.1.64 renewed by host android-​f00ef7681ff2988a (MAC 64:bc:0c:69:cc:41). Lease duration: 1440 min
18:19:54, 13 Jan.(503410.900000) Device connected: Hostname: android-​f00ef7681ff2988a IP: 192.168.1.64 MAC: 64:bc:0c:69:cc:41 Lease time: 1440 min. Link rate: 20.2 Mbps
18:19:54, 13 Jan.(503410.830000) Lease requested
18:19:54, 13 Jan.(503410.580000) Device disconnected: Hostname: AdriennesiPhone IP: 192.168.1.79 MAC: 88:63:df:70:3a:92
18:19:50, 13 Jan.ath00: STA 64:bc:0c:69:cc:41 IEEE 802.11: Client associated
18:19:48, 13 Jan.(503405.070000) Device disconnected: Hostname: AdriennesiPhone IP: 192.168.1.79 MAC: 88:63:df:70:3a:92
18:19:48, 13 Jan.(503405.070000) Device disconnected: Hostname: android-​f00ef7681ff2988a IP: 192.168.1.64 MAC: 64:bc:0c:69:cc:41
18:19:47, 13 Jan.ath00: STA 64:bc:0c:69:cc:41 IEEE 802.11: Client disassociated
18:19:38, 13 Jan.(503395.060000) Device disconnected: Hostname: AdriennesiPhone IP: 192.168.1.79 MAC: 88:63:df:70:3a:92
18:19:37, 13 Jan.(503393.380000) Lease for IP 192.168.1.46 renewed by host MichalsiPhone8 (MAC 9c:f4:8e:ec:11:99). Lease duration: 1440 min
18:19:37, 13 Jan.(503393.380000) Device connected: Hostname: MichalsiPhone8 IP: 192.168.1.46 MAC: 9c:f4:8e:ec:11:99 Lease time: 1440 min. Link rate: 105.6 Mbps
18:19:36, 13 Jan.(503393.260000) Lease requested
18:19:33, 13 Jan.ath00: STA 9c:f4:8e:ec:11:99 IEEE 802.11: Client associated
18:18:57, 13 Jan.(503353.710000) Device disconnected: Hostname: AdriennesiPhone IP: 192.168.1.79 MAC: 88:63:df:70:3a:92
18:18:57, 13 Jan.(503353.710000) Device disconnected: Hostname: MichalsiPhone8 IP: 192.168.1.46 MAC: 9c:f4:8e:ec:11:99
18:18:56, 13 Jan.(503352.680000) Lease for IP 192.168.1.64 renewed by host android-​f00ef7681ff2988a (MAC 64:bc:0c:69:cc:41). Lease duration: 1440 min
18:18:56, 13 Jan.(503352.680000) Device connected: Hostname: android-​f00ef7681ff2988a IP: 192.168.1.64 MAC: 64:bc:0c:69:cc:41 Lease time: 1440 min. Link rate: 29.0 Mbps
18:18:56, 13 Jan.(503352.610000) Lease requested
18:18:53, 13 Jan.ath00: STA 64:bc:0c:69:cc:41 IEEE 802.11: Client associated
18:18:51, 13 Jan.(503347.790000) Device disconnected: Hostname: AdriennesiPhone IP: 192.168.1.79 MAC: 88:63:df:70:3a:92
18:18:51, 13 Jan.(503347.790000) Device disconnected: Hostname: MichalsiPhone8 IP: 192.168.1.46 MAC: 9c:f4:8e:ec:11:99
18:18:51, 13 Jan.(503347.790000) Device disconnected: Hostname: android-​f00ef7681ff2988a IP: 192.168.1.64 MAC: 64:bc:0c:69:cc:41
18:18:50, 13 Jan.ath00: STA 64:bc:0c:69:cc:41 IEEE 802.11: Client disassociated
18:18:48, 13 Jan.(503344.880000) Lease for IP 192.168.1.64 renewed by host android-​f00ef7681ff2988a (MAC 64:bc:0c:69:cc:41). Lease duration: 1440 min
18:18:48, 13 Jan.(503344.880000) Device connected: Hostname: android-​f00ef7681ff2988a IP: 192.168.1.64 MAC: 64:bc:0c:69:cc:41 Lease time: 1440 min. Link rate: 24.5 Mbps
18:18:48, 13 Jan.(503344.820000) Lease requested
18:18:40, 13 Jan.ath00: STA 64:bc:0c:69:cc:41 IEEE 802.11: Client associated
18:18:37, 13 Jan.ath00: STA 64:bc:0c:69:cc:41 IEEE 802.11: Client disassociated
18:18:35, 13 Jan.OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 86.166.110.63-​>31.13.90.2 on ppp0)
18:18:35, 13 Jan.(503332.140000) Lease for IP 192.168.1.64 renewed by host android-​f00ef7681ff2988a (MAC 64:bc:0c:69:cc:41). Lease duration: 1440 min
18:18:35, 13 Jan.(503332.140000) Device connected: Hostname: android-​f00ef7681ff2988a IP: 192.168.1.64 MAC: 64:bc:0c:69:cc:41 Lease time: 1440 min. Link rate: 24.5 Mbps
18:18:35, 13 Jan.(503332.070000) Lease requested
18:18:27, 13 Jan.ath00: STA 64:bc:0c:69:cc:41 IEEE 802.11: Client associated
18:18:27, 13 Jan.ath00: STA 64:bc:0c:69:cc:41 IEEE 802.11: Client disassociated
18:18:23, 13 Jan.(503319.340000) Lease for IP 192.168.1.64 renewed by host android-​f00ef7681ff2988a (MAC 64:bc:0c:69:cc:41). Lease duration: 1440 min
