teegee777
Message 1 of 6
Internet connection slow/not responding
I've been having trouble at home with long delays in responses from requests for websites etc. The internet effectitively seems to freeze and doesn't move. This can happen at various times of day and last night there was no service for at least 30 minutes, (the broadband was up all this time with blue lights.) This seems to be a problem from our exchange as I visit and help some "silver surfers" and they complain about similar issues. The exchange has just had another Infinity cabinet installed in the village and perhaps coincidentally we seem to regularly change our "home" location if I do a google search, currently Stanton (Suffolk). I've tried a Google DNS instead of BT but that doesn't appear to be any better. Last night I managed to get some "wireshark" traces and the DNS is not sending a response to the query, but I think this probably points to other network issues as it seems to happenon Google DNS as well. Any thoughts on how I could progress this issue?
5 REPLIES 5
Message 2 of 6
Re: Internet connection slow/not responding
in order for the forum members to help please can you post the adsl stats from your router you may need to 'show detail' to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or if HH4/5 then go to troubleshooting then logs and you are looking for 2 line together when hub last connected to internet and they will show your connection speed and noise margin or if netgear enter 192.168.0.1). Then run  btspeedtester  (MAC users may have problems). when first test completes then run diagnostic test and post the results ( do not reset the router).
can you enter your phone number and post results  remember to delete number  https://www.btwholesale.com/includes/adsl/main.html
are you connected directly via a filter to the NTE5 master or test socket or to somewhere else? Is the master the only phone socket in your home?
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
Someone may then be able to offer help/assistance/suggestions to your problem
teegee777
Message 3 of 6
19:52:09, 02 May.
DSL Link Up: Down Rate=8128Kbps, Up Rate=448Kbps; SNR Margin Down=6.6dB, Up=25.0dB
DSL uptime:
9 days, 21:39:23
Data Rate:
448 / 8128
Maximum Data Rate:
1220 / 8908
Noise Margin:
25.0 / 6.6
Line Attenuation:
16.5 / 22.0
Signal Attenuation:
0.0 / 22.0
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
ADSL Max
Up to 5.5
4 to 8
Available
Fixed Rate
2
Available
 Ethernet connected, from Hub, Hub connected to face plate filtered master socket, no noise on line
Message 4 of 6
you are on adslmax with the max speed of 8mb  your exchange has not been upgraded for 21cn (adsl2) of fiber FTTC  your stats look ok with correct profile and download speed 5mb+
is there any problems shown for your exchange  http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
http://community.plus.net/exchange-information/
the installing of a fibre cab should not have any affect on your adsl connection
Message 5 of 6
have you tried a factory reset of hub using the recessed button on back and holding until lights flash?
teegee777
Message 6 of 6
Yes, I have tried a full reset, however as per my original post I am not the only one affected, there are a lot of people in the exchange area suffering the same issue. It would appear to be a network failure of some sort. My broadband connection doesn't drop and the speed at all other times is reasonable. It does affect mail applications as well, so isn't just websites. this was last nights trace.
No. Time         Source               Destination      Protocol Length      Info
4    3.759794 192.168.1.176    192.168.1.254    DNS        70        Standard query A www.bt.com
5    4.009255 192.168.1.176    224.0.0.22 IGMP 54 V3 Membership Report / Join group 239.255.255.250 for any sources
6    4.649533 fe80::2d2c:127a:db2d:79dc ff02::c SSDP 208 M-SEARCH * HTTP/1.1
7    4.773843 192.168.1.176    192.168.1.254    DNS        70        Standard query A www.bt.com
8    5.259739 192.168.1.239     192.168.1.255   NBNS       92       Name query NB WPAD<00>
9    5.271169 fe80::d0b2:629a:c6f5:a53 ff02::1:3 LLMNR    84       Standard query A wpad
10  5.272055 192.168.1.239 224.0.0.252           LLMNR     64       Standard query A wpad
11  5.272881 fe80::d0b2:629a:c6f5:a53 ff02::1:3 LLMNR 84 Standard query AAAA wpad
12  5.272882 192.168.1.239 224.0.0.252 LLMNR 64 Standard query AAAA wpad
13  5.412695 9c:80:df:71:4f:15 Broadcast ARP 60 Who has 192.168.1.64? Tell 192.168.1.254
14  5.676639 fe80::d0b2:629a:c6f5:a53 ff02::1:3 LLMNR 84 Standard query A wpad
15  5.676641 192.168.1.239 224.0.0.252 LLMNR 64 Standard query A wpad
16  5.678474 fe80::d0b2:629a:c6f5:a53 ff02::1:3 LLMNR 84 Standard query AAAA wpad
17  5.678475 192.168.1.239 224.0.0.252 LLMNR 64 Standard query AAAA wpad
18  6.010371 192.168.1.239 192.168.1.255 NBNS 92 Name query NB WPAD<00>
19  6.351141 9c:80:df:71:4f:15 Broadcast ARP 60 Who has 192.168.1.167? Tell 192.168.1.254
20  6.506423 192.168.1.176 224.0.0.22 IGMP 54 V3 Membership Report / Join group 224.0.1.60 for any sources
21  6.763415 192.168.1.239 192.168.1.255 NBNS 92 Name query NB WPAD<00>
22  6.787434 192.168.1.176 192.168.1.254 DNS 70 Standard query A www.bt.com
23  7.284130 9c:80:df:71:4f:15 Broadcast ARP 60 Who has 192.168.1.250? Tell 192.168.1.254
24  7.649567 fe80::2d2c:127a:db2d:79dc ff02::c SSDP 208 M-SEARCH * HTTP/1.1
whereas a good trace this morning
59    7.442560 192.168.1.176     192.168.1.254       DNS           71      Standard query A home.bt.com
60    7.479142 192.168.1.254     192.168.1.176       DNS         139      Standard query response CNAME btgroup-5.hs.llnwd.net A 178.79.201.80 A 178.79.206.253
