Message 1 of 4
Internet dropping on a missed call
Hello
I have a strange issue which i couldnt find any information on. When i miss a call on my land line phone it causes the internet to drop out and have to reconnect. If the phone is answered then the internet will not drop out.
I have changed all the filters and no change.
I checked the line on the silent line check and there was some interference on the line; however it was using a wireless phone.
What would the likely cause of this issue be?
Adam
3 REPLIES 3
Message 2 of 4
Re: Internet dropping on a missed call
With cordless phone a dull hum is normal and anything else is a problem and need to be reported to 151as a phone fault - no mention of broadband
Message 3 of 4
Thanks for the quick reply, however i was more looking at what would cause this from a technical stand point, and whether it would likely be a problem inside my property?
Adam
Message 4 of 4
if you connect your phone to the test socket and the noise is still there then the fault is outside your home
