singy206
Message 1 of 5
Internet problem after wires reconnected
Hello to everyone , my first post. I have bt broadband and it has been working fine not super fast but ok for me , recently my girlfriend managed to pull all the wires out of the main socket coming into my house, the main socket is in a small hallway that was rebuilt a few years ago and the builders just connected the wires inside a junction box not bt standared but it's been working ok so I have just left it, I reconnected the wires and asked bt to check the line and they said everything was fine and to be honest the phone is working perfect but the Internet has not been right , I struggle to load any pages it's as if it's only working on half power, if I try to down load match of the day it is trying but after about an hour it's only down loaded 5% then it just gives up , is this something to do with my settings ? I haven't changed anything on any of my devices , they are all very poor , I know very little about these things if anyone can point me in the right direction before I get bt out that would be great. thanks Mark.
4 REPLIES 4
Message 2 of 5
Re: Internet problem after wires reconnected
Welcome to this user forum.
Are you connected to your BT Broadband connection at the moment?
Which BT Home hub do you have?
XRaySpeX
Recognised Expert
Message 3 of 5
Please post your full Router Stats. For a Home Hub see on here: Broadband Top Tips . Full router stats are key to any speed & connection issues.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
Message 4 of 5
can you post a photo of your socket and wiring?
singy206
Message 5 of 5
Thanks very much for the quick response I'll get all the information together and post it as soon as I can, it is difficult as it takes my iPad 30 mins to load this page . thanks Mark
