Derbydan16
Message 1 of 11
Internet suddenly stopped - solid blue light
Hi all, the other night all my devices (mac, android, TV etc) just disconnected and since then I've not had boardband... My hub6 has a solid blue light which according to live chat means all is ok. Ive logged into the hub and it says it connected, but no devices are working and web pages on my Mac book come up with the error secure connection failed... Anyone have any ideas
Tags (1)
10 REPLIES 10
Message 2 of 11
Re: Internet suddenly stopped - solid blue light
Try resetting it.
Derbydan16
Message 3 of 11
I've done that, and reset it and had bt run a test and they said it all fine
Message 4 of 11
Unplug it from the phone socket, wait about three minutes, then plug it back in again and wait for the light to go blue again. That should give you a different public IP address, just in case you are connected to a stale session.
Is anything connected using an Ethernet cable, and does it work? Is it just wireless devices that are affected?
Poppy7
Message 5 of 11
Most likely you will need a replacement. Seem to be a lot of faulty HH6 out there.
Derbydan16
Message 6 of 11
Ahhhh getting somewhere, Ethernet is working, plugged into sky box, wireless not. Does that sound faulty?
fosterl2
Message 7 of 11
Might be worth trying a factory re-boot. There is usually a small button that has to be pressed with a paperclip for 10 seconds.
Moderator
Moderator
Message 8 of 11
Hi @Derbydan16 and thanks for posting.
As @fosterl2 has mentioned, a factoy reset might help. You can find instructions on how to do that at How do I reset my BT Hub to its factory settings? Can you let me know if that helps?
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Derbydan16
Message 9 of 11
Hi, I've Tried that also, nothing is working, seems like a hardware issue. I've contacted bt and they are going to send me a new hub 6. Thanks for all your help
Moderator
Moderator
Message 10 of 11
Let us know how you get on with the new hub @Derbydan16.
Cheers
David
Kudos”
