sheilajoe
Message 1 of 40
Ip profile
hi new to this i have contacted bt help line many times in 2 months regards to my poor speed, i was told that it was because my ip profile was on 2mbps so i was told it would be changed wait 10 days then will be back to normal i have now waited 3 lots of 10 days and still when i do a bt wholesales speed test its is still saying ip profile is on 2mbps i am really needing some real help now as it has been 2 months with this issue, i am ment to be getting 8 mbps still not that fast but better then 0.67 mpbs kind regards sheila
39 REPLIES 39
Message 2 of 40
Re: Ip profile
Can you post your adsl stats from your router and the run btspeedtesr and when first test completes then run diagnostic test and post results
Message 3 of 40
Re: Ip profile
Hi Welcome to the community forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
sheilajoe
Message 4 of 40
Re: Ip profile
hi im jolly how do i get adsl stats thanks
Message 5 of 40
Re: Ip profile
Enter 192.168.1.254 into your browser then you should find the adsl stats remember to shwo detail at bottom to get errors information
sheilajoe
Message 6 of 40
Re: Ip profile
it just comes up bt home hub manager here is the results from bt wholesale speedtest
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
Download Speed
0.03 Mbps
0 Mbps 2 Mbps
Max Achievable Speed
Download speedachieved during the test was - 0.03 Mbps
For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 2 Mbps
Message 7 of 40
Re: Ip profile
When you get hub manager then you need to login - probably user admin and password on the hub. Once you get into hub-then you should get hub stats
It certainly looks like your profile is stuck at 2mb
sheilajoe
Message 8 of 40
Re: Ip profile
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 00:58:17
Downstream:7.938 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Fast
Noise margin (Down/Up):9.9 dB / 21.0 dB
Line attenuation (Down/Up):17.8 dB / 10.0 dB
Output power (Down/Up):19.8 dBm / 11.9 dBm
FEC Events (Down/Up):0 / 382
CRC Events (Down/Up):82941 / 436
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):213717 / 114
Error Seconds (Local/Remote):4010 / 660
sheilajoe
Message 9 of 40
Re: Ip profile
hi posted some more stats thank you so much for looking
Message 10 of 40
Re: Ip profile
Now need you to repost the adsl when connection time shows 3days to show stable connection and then mods will help fix your profile which should be 7.15mb
