Message 21 of 40
Re: Ip profile
Your profile is low so get that fixed by mods first and then you will get a better idea if all the errors are causing a throughput problem especially at night. If so then come back and post new stats
sheilajoe
Message 22 of 40
Re: Ip profile
thankyou for all your help, i could not stand the idea of having to ring the call centre again
Message 23 of 40
Re: Ip profile
Glad help anytime
sheilajoe
Message 24 of 40
Re: Ip profile
hi just wanted if you had any luck with my broadband thanks
Message 25 of 40
Re: Ip profile
the mods will get in touch with you personally it may take a few days
sheilajoe
Message 26 of 40
Re: Ip profile
i dont think it has been fixed not sure what i should do next !
FAQ
Results Image not loaded
1. Best Effort Test:  -provides background information.
 Download  Speed
 0.61 Mbps
0 Mbps2 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.61 Mbps
 For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
 Additional Information:
 Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 2 Mbps
If you wish to discuss these results please contact your Broadband Service Provider.
If you are experiencing problems with specific applications, servers or websites please contact your Broadband Service Provider for assistance.
Your test has completed please close this window to exit the performance tester.
Please visit the FAQ if you are unable to understand the test results.
sheilajoe
Message 27 of 40
Re: Ip profile
ok thankyou john
Message 28 of 40
Re: Ip profile
just wait while the mods contact you
sheilajoe
Message 29 of 40
Re: Ip profile
4 days with no reply or speed change think its best i change provider thanks for all your help
Message 30 of 40
Re: Ip profile
just wait for mods they will fix it
