Moderator-Retired
Message 31 of 40
Re: Ip profile
I can see your email in our queue Sheila, it should be picked up within the next 24 hours and fixed before the end of the weekend.
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
sheilajoe
Message 32 of 40
Re: Ip profile
thankyou for letting me know, my speed today is is 0.36 can hardly use this site its that slow
sheilajoe
Message 33 of 40
Re: Ip profile
dear mods i have been very patient with my broadband and for the issue to be resolved, i keep getting the same replys on the forum and on the telephone, it has now been 3 months with no solution i do not understand why the ip profile has yet to be changed, i can appreciate the volume of problems you are dealing with how ever if you are unable to fix thi issue then i have no choice but to cancel regards sheila
Tags (1)
Message 34 of 40
Re: Ip profile
the IP Profile will be reset it is just taking a little longer than normal
sheilajoe
Message 35 of 40
Re: Ip profile
can you explain why it takes so long
Message 36 of 40
Re: Ip profile
there has obviously a delay in getting the reset done due to a high number of faults caused by the recent storms the mods will not let you down it will get reset
sheilajoe
Message 37 of 40
Re: Ip profile
i understand that but we have not had storms for the duration of my faulty broadband and i also am paying for broadband that im not getting im just getting frustrated not being able to watch tv or go online
Message 38 of 40
Re: Ip profile
i can understand the frustration but at present it is taking about 6 working days excludes weekends for mods to get back to you
Moderator
Moderator
Message 39 of 40
Re: Ip profile
Hi sheilajoe,
I have your email and I'll be in touch shortly.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
sheilajoe
Message 40 of 40
Re: Ip profile
thankyou so much
