Paigntonian
Message 1 of 5
It all started so well!
Guys, Im fed up!
2 months ago I was with Be, and never had a problem, I switched to BT to get btvision.
Switch over was perfect, all was well untill the past few days.
Numerous problems with the wireless later, it seems sorted, so... onto the next problem.
My throughput speed and line profile is ok, not the 19meg I had from Be, but its acceptable, bearing in mind the snr is a little hi and bt wont drop it..
Anyway, I have been having problems streaming videos and loading pages, even though the speed is acceptable.
Belows is the reason....[URL=http://www.pingtest.net][IMG]http://www.pingtest.net/result/32452076.png[/IMG][/URL]
I have reported it to India, dont have a clue what Im on about, or how to fix it, so Im currently in a queue
for the cancellation dept.
Heres a stats sheet by the way.
Line stateConnected
Connection time1 day, 0:46:19
Downstream16,237 Kbps
Upstream1,219 Kbps
ADSL settings<script type="text/javascript">// createTable("normal", trClass, td3, td4); // </script>
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)4.0 dB / 5.9 dB
Line attenuation (Down/Up)27.5 dB / 13.8 dB
Output power (Down/Up)0.0 dBm / 12.7 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)6526392 / 4294967264
CRC Errors (Down/Up)235 / 2147480000
HEC Errors (Down/Up)nil / 0
Error Seconds (Local)127
------Marc------
4 REPLIES 4
Paigntonian
Message 2 of 5
Re: It all started so well!
Dont know why the ping test link is broke.
Basically it shows ping at 230, jitter 124, packet loss 45%
------Marc------
Tags (2)
Paingiver
Message 3 of 5
Actually "It's worse than we thought Jim!" as that link shows...
ping at 640, jitter 920, Unable to test packet loss!
Paigntonian
Message 4 of 5
Thats what I ment...
(I read the last test by mistake)
Doh!!!
BT tech just rang, apparantly theres no fault with my service...
I beg to differ!!
------Marc------
Paigntonian
Message 5 of 5
