Message 41 of 74
Re: Junction box.......
up to you just that is 8 days already
shirts
Recognised Expert
Message 42 of 74
It appears that the exchange and hub are coming to a mutually agreeable solution.........shall give it another couple of days...
Event Log
This page summarises all the recent events that have been recorded on your BT Home Hub.
You can filter the events to show items related to a specific category.
Category
click to change category dropdown
Recorded events
Time and date Message
18:23:34, 02 Jul.(864046.860000) CWMP: session completed successfully
18:23:34, 02 Jul.(864046.560000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
18:23:30, 02 Jul.(864042.770000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
18:23:30, 02 Jul.(864042.760000) CWMP: Session start now. Event code(s): '2 PERIODIC,4 VALUE CHANGE'
18:23:28, 02 Jul.(864040.970000) CWMP: Initializing transaction for event code 2 PERIODIC
18:23:38, 01 Jul.(777645.110000) CWMP: session completed successfully
18:23:38, 01 Jul.(777644.830000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
18:23:34, 01 Jul.(777640.960000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
18:23:34, 01 Jul.(777640.950000) CWMP: Session start now. Event code(s): '2 PERIODIC,4 VALUE CHANGE'
18:23:32, 01 Jul.(777638.740000) CWMP: Initializing transaction for event code 2 PERIODIC
18:23:43, 30 Jun.(691243.650000) CWMP: session completed successfully
18:23:43, 30 Jun.(691243.360000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
18:23:38, 30 Jun.(691238.730000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
18:23:38, 30 Jun.(691238.710000) CWMP: Session start now. Event code(s): '2 PERIODIC,4 VALUE CHANGE'
18:23:36, 30 Jun.(691236.890000) CWMP: Initializing transaction for event code 2 PERIODIC
If you found this post helpful, then please click the star on the left, after all, I'm only trying to help........Smiley Wink
shirts
Recognised Expert
Message 43 of 74
Have just restarted the hub and noise margin has come down. Smiley Happy
Errors not coming through at the moment.........
ADSL Line Status
Connection Information
Line state:Connectedppp0_0
Connection time:0 days, 00:21:58
Downstream:9.492 Mbps
Upstream:1.143 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):9.4 dB / 5.9 dB
Line attenuation (Down/Up):17.0 dB / 9.3 dB
Output power (Down/Up):14.4 dBm / 12.1 dBm
FEC Events (Down/Up):45 / 15
CRC Events (Down/Up):0 / 32
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):0 / 8
Error Seconds (Local/Remote):0 / 0
Message 44 of 74
strangely speed is exactly the same but at least the errors have zeroed so can see how fast the accumulate
shirts
Recognised Expert
Message 45 of 74
I must admit I thought the speed would have gone up with the reduction in noise margin........especially when you consider the speedtest shows the download speed greater than the ip profile........Smiley Surprised
Message 46 of 74
the hub log you have posted is showing the hub contacting the update server for hub firmware updates
shirts
Recognised Expert
Message 47 of 74
Ah.....my apologies. I thought that the hub stats shown were part of the dlm negotiating with the hub as to the best connection speed that could exist between the two. I didn't realise that this was to do with checking the hub's firmware.....!
shirts
Recognised Expert
Message 48 of 74
While you two gentlemen are about, could you please explain why very little mention is made on these forums of the program called "routerstatshub" ? I have found it to be GREAT at monitoring the interference on my connection, and invaluable for narrowing down the source and the volume of said interference ! ie. is it a sudden burst, or does it come through continuously....It is also good for indicating the benfits of any changes I make........
Message 49 of 74
probably beacuse it is relatively new and is for HH3 a or b
I use it with my netgear and have done for years
shirts
Recognised Expert
Message 50 of 74
obviously I am in good company.....Smiley Happy I just thought it might help a number of people on this forum......
