Mazz71
Message 1 of 12
Just a quick question re my broadband speed.
Hi (again)
The advertised speed (from BT's choose for package page) for my line is 8.5Mb-13Mb, but I only ever have 5meg max (on a good day)?
Just wondered.
Mazz
11 REPLIES 11
Message 2 of 12
Re: Just a quick question re my broadband speed.
Run btspeedtester and see what it says. http://speedtest.btwholesale.com/
Mazz71
Message 3 of 12
Yes I have. The speed is no where near.
Do I have a fault with my line maybe?
Mazz
Mazz71
Message 4 of 12
Even the BT Tech guys have told me only to expect 5-6meg 😞
Mazz
Mazz71
Message 5 of 12
IP Profile - 4Meg
Acceptable range - 0.6 to 7.5meg
Mazz
Message 6 of 12
You need to find your adsl stats and your attenuation and from at you will get a good idea of connection speed. Try this link see if it helps. http://www.kitz.co.uk/adsl/frogstats.php
Mazz71
Message 7 of 12
DSL Connection
Link Information
Uptime: 0 days, 0:31:02
Modulation: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,520
Data Transferred (Sent/Received) [MB/MB]: 24.97 / 591.14
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 17.0 / 34.0
SN Margin (Up/Down) [dB]: 21.0 / 6.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 0 / 0
FEC Errors (Up/Down): 0 / 121
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Line Profile: Interleaved
Message 8 of 12
You are on adlmax and have a connection speed of 7.5mb. Your connection time is only 31 min is that due to router dropping connection or manual reset?
Mazz71
Message 9 of 12
I've had connection problems, and I did a manual reset.
So.... How do i actually achieve connection speed of 7.5mb?
Message 10 of 12
With your current connection speed your profile should be 6.5mb giving a download speed of about 6 mb on a good line. You can see here. http://www.kitz.co.uk/adsl/IPprofile.htm
