magiK
Message 1 of 3
Just curious
I am unsure if this is the right speed for my line attenuation. Almost every chart I look at, Kitz etc. suggests that I should be getting a connection of 4+ mbps instead of the measly 2.5 mbps I am getting right now. Here is a screenshot of my router stats (BTHub3)
I have also noticed that my noise margin has increased from around 3db to 6db.
Not complaining, just wondering if I can squease anymore out of my connection.
Cheers
2 REPLIES 2
Message 2 of 3
Re: Just curious
Your noise margin has risen to the standard default setting in an attempt to stabilise the connection the 3 dB margin is set by the DLM only if the line is stable and has low errors
sync speeds can vary from line to line
magiK
Message 3 of 3
Re: Just curious
It's a struggle. I had a 4mb connection before an engineer came to fix a noise issue, everything is fine now but my speed reduced by half. I addressed this with the engineer, he said a profile reset would fix the issue but nothing changed 😧 Is there anything I can do to help get my connection back to 4mb?
