Do you mean
Newbie
Laptop/PC/iPad all disconnects from the BT Home Hub
Hi, around once or twice a day my laptop, PC and iPad all suddenly looses connectivity with the BT Home Hub. However everthing else still connects (PC - which is connected by cable, BT Vision, BT Talk etc)
On my laptop or PC it can still pick up the router so when I click connect it doesn't work. I click repair and it says I need to restart my router. I do this and it works.
It is getting really annoying that I have to keep restarting the router becasue it means that BT vision will be restart and everything else etc.
Is there a fix?
Re: Laptop/PC/iPad all disconnects from the BT Home Hub
[ Edited ]
welcome to the forum
try downloading and running inssider.  This will show networks round about and their channel so you can try and pick a free one for yourself.  just enter 192.168.1.254 in your browser and navigate to wireless to turn off automatic and select your channel
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
