Message 1 of 3
Line reset request: 3+ days stable
Hi all
hoping you can help me again, as you did about 2 years ago. Did some testing with my internal phones lines, several resets on the router, etc, and was put into the stupid banded profile.
The connection has been stable for 3+ days but the profile hasn't normalised yet. Could you do a line reset for me? Not sure if you can help, I am on Sky currently but since this is an Openreach issue, I'm hoping the answer is yes!
System Up Time 3 days 13:51:20
PortStatusTxPktsRxPktsCollisionsTx B/sRx B/sUp Time
WANpppoa542987987224420200794363 days 13:12:20
LAN1Link Down5659702713814784090207038--
LAN21000M3 days 13:46:38
LAN3Link Down--
LAN41000M00:16:58
WLAN b/g/n300M15296631049319044297043 days 13:50:39
WLAN a/n300M17851703558576130414769523 days 13:50:39
ADSL LinkDownstreamUpstream
Connection Speed2591 kbps381 kbps
Line Attenuation44.0 db45.9 db
Noise Margin10.9 db6.4 db
2 REPLIES 2
Message 2 of 3
Re: Line reset request: 3+ days stable
This is a BT Retail Forum not an Openreach one and even if it was they still couldn't do an SNR Reset as Sky own their own LLU Network so they would do the reset themselves.
Openreach Engineers can't reset Sky LLU SNR's, they have to call Sky to do it for them.
Message 3 of 3
Ok thanks. Thought it was worth checking... off to call sky then
