DiggerOfTrenches
Message 111 of 113
Re: Line reset yet again please
Unfortunately even if your broadband deliverers you a great pile of S...e.
You singed a contract for that pile of S...e.
Retail customers are considered S...e.
You, believing the hype, ordered the hyped S...e. and receive S...e without the hype for 18months with little choice.
You are truly F....d even if you persist.
Do not give up! That would be inconvenient!
So unless they lied through their teeth when you moved house, all calls recorded, you're wasting your time.
Helps? No the BOC.
kelvinbridge
Message 112 of 113
quote ##Your connection should reset itself given a stable connection for 7/10 days. ##
and how pray could anyone get 7/10 days connection in the jolly old bt hub keeps disconnecting ? ?
kelvinbridge
Message 113 of 113
Dear Digger I really like your wry sense of humour obviously you don't work for the bt chicken farm down the road !!
