mikeod71
Message 1 of 10
Local Exchange Upgraded to Adsl2+ - would there by a speed increase and how to upgrade if so
Hello,
I've enclosed my Home Hub 3 ADSL stats as I've learnt my local exchange has been upgraded to ADSL2+ and i'm wondering whether we can upgrade and if it would be worth doing -and how you go about it if so.
At present we get 1.5Mb roughly so any increase would be most useful. We can not get bt fibre. We are approximately 3Km from the exchange.
In advance many thanks for your help.
ADSL Line Status
Connection Information
Line state:Connected
Connection time:4 days, 15:37:45
Downstream:1.5 Mbps
Upstream:256 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):13.4 dB / 6.0 dB
Line attenuation (Down/Up):58.2 dB / 31.5 dB
Output power (Down/Up):18.3 dBm / 12.5 dBm
FEC Events (Down/Up):150160 / 16339
CRC Events (Down/Up):155 / 3178
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):755 / 1430
Error Seconds (Local/Remote):377 / 3726
9 REPLIES 9
Message 2 of 10
Re: Local Exchange Upgraded to Adsl2+ - would there by a speed increase and how to upgrade if so
can you enter your phone number and post results  remember to delete number  https://www.btwholesale.com/includes/adsl/main.html
Message 3 of 10
your noise margin is very high at 13.4db have you been having problems with conenction dropping or was it manual reset?  you have 4 days connection time so appears to have stabilised but your up speed is low as it should be 448kbps
are you using te test socket with a new filter or have you tried the test socket? test socket.jpg
mikeod71
Message 4 of 10
THanks for responding - here are the details...
Telephone Number XXXXXXXXX on Exchange MELBOURN is served by Cabinet 3
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
WBC ADSL 2+Up to 17--10 to 19.5Available
WBC ADSL 2+ Annex MUp to 17Up to 1.510 to 19.5Available
ADSL MaxUp to 7.5--6.5 to 8Available
WBC Fixed Rate2----Available
Other Offerings
Fibre Multicast------Available
Copper Multicast------Available
For all ADSL and WBC Fibre to the Cabinet (FTTC or WBC SOGEA) services, the stable line rate will be determined during the first 10 days of service usage.
There are no left in jumpers available on this line. This line is on a Market B Exchange.
Throughput/download speeds will be less than line rates and can be affected by a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for Datastream is from 30-Jun-2012; the Formal Retirement date for Datastream is from 30-Jun-2014. The Stop Sale date for IPstream is from 31-Oct-2013; the Formal Retirement date for IPstream is from 30-Jun-2014.
If the End User wishes to migrate from their current Broadband supplier they will need to contact the Broadband supplier they want to take service from to arrange for the service to be migrated.
Note: Please note that postcode and address check results are indicative only. Most accurate results can be obtained from a telephone number check.
Thank you for your interest.
mikeod71
Message 5 of 10
Hi, thanks for responding.
We occasionally need to reset the router but in general it is not a problem.
I did try the test socket, the download limit increased marginally from about 1.5Mbs to 1.8Mbs.
I can re-do it and provide the noise margin details if that'd be useful ??
Thanks again
Mike
Boudges
Message 6 of 10
How many times a day do you reset the router? This could be the cause of your high noise margins resulting in your low speeds.
Your DSL check shows max speeds for the phone number you used yet you have a 58db attenuation suggesting (as you said) a 3km+ line length which normally only gets speeds anywhere between 1-4 mbps download.
ADSL2+ is more aggresive on line noise and upgrading to it could make matters worse. You could expect about a 100% increase in upload speed though.
If you liked a post, please click on the 'Ratings star' on the left hand side of the post.
Message 7 of 10
as you have already posted stats showing connection stable can you conenct direct to test socket without an extension cable with a new filter and repost your router stats please     when you connect to test socket are all your other internal phone sockets 'dead'
Message 8 of 10
Strange how you can't get FTTC. Cabinet 3 on Melbourn exchange was live for FTTC in December 2014.
Boudges
Message 9 of 10
Possible that he is far from the cabinet
Message 10 of 10
Yes it would appear the cabinet is quite close to the exchange, within a couple of hundred meters. What is your post code OP?
Test socket check required....
