Linksidian
Message 1 of 9
Low BB speed on new line
Have just moved house and had a new business line installed 7 days ago.. contract stated maximum ADSL download speed would be 3Mbps, but so far have managed a maximum of 0.2Mbps
Have just run a test on BT Wholesale and showing the following;
For your connection, the acceptable range of speeds is 0.1 Mbps-0.25 Mbps
IP profile of your line is - 0.21 Mbps
The connection has been like this now for 7 days with no signs of improvement, is this normal and can I expect a sudden increase after 10 days?
Have spoke to BT but they say they can't do anything until 10 days are up, but why am I still not getting what the contract states? We have checked with neighbours and they are getting speeds between 2 - 3 Mbps..
Trying to run a business with 0.2Mbps download is proving virtually impossible..!
8 REPLIES 8
Message 2 of 9
Re: Low BB speed on new line
as you are a business user you need to post on this forum  https://business.forums.bt.com/
this forum is for residential customers
Linksidian
Message 3 of 9
Trying anything to be honest as tearing my hair out.. but will post on Business forum.. was hoping someone could just say whether this is normal or not..
Message 4 of 9
your profile is very low - can you post your current connection speed from your hub
Linksidian
Message 5 of 9
0.2 Down, 0.19 Up
Message 6 of 9
if HH4 can you go to hub manager 192.168.1.254 then troubleshooting then helpdesk and post the stats
Linksidian
Message 7 of 9
Information for Helpdesk agents
When contacting the BT Business Broadband helpdesk, the agent might ask you for details about your BT Hub. This page contains all of the information they are likely to request.
1. Product name:BT Hub
2. Serial number:NQ32661653
3. Firmware version:Software version 4.7.5.1.83.8.82.1.1 (Type A) Last updated Unknown
4. Board version:BT Business Hub 3.0A
5. ADSL uptime:0 days, 08:42:03
6. Bandwidth:80 / 239
7. Data sent/received:0.0 / 0.2
8. Broadband username:D479341@hg70.btclick.com
9. BT Wi-fi:Yes
10. Static IP:No
11. Wireless network/SSID:BTHub3-Z66W
12. Wireless connections:Enabled, (802.11 b/g/n (Recommended)) 20 MHz, WPS enabled
13. Wireless security:WPA and WPA2
14. Wireless channel:Automatic / 1
15. Firewall:Default
16. MAC Address:cc:33:bb:89:4c:64
17. VPI/VCI:0 / 38
18. Line profile:Interleaved
19. Software variant:-
20. Boot loader:-
Message 8 of 9
your conenction speed is very low - are you connnected to test socket with a new filter.  if so then you need to get an engineer visit
Linksidian
Message 9 of 9
Thanks, I was connected to test socket with new filter but made no difference so have reverted back to actual socket..
Will contact again and ask for engineer visit.. appreciate the advice
