GlebeCS
Message 1 of 3
Low IP profile, high SNR
Hi all, I am not sure why I am getting such low speeds on BT Broadband, my current connection has been up for 4 days and 10 hours and my Billion stats show:
xDSL
ModeADSL_G.dmt
Traffic TypeATM
StatusUp
Link Power StateL0
 DownstreamUpstream
Line Coding (Trellis)OnOn
SNR Margin (dB)15.119.0
Attenuation (dB)45.028.5
Output Power (dBm)18.712.1
Attainable Rate (Kbps)40081040
Rate (Kbps)3168448
K (number of bytes in DMT frame)10015
R (number of check bytes in RS code word)168
S (RS code word size in DMT frame)2.002.00
D (interleaver depth)164
Delay (msec)8.008.00
INP (DMT symbol)0.590.09
Super Frames4846365748463657
Super Frame Errors36501062
RS Words763168607190791680
RS Correctable Errors81372344
RS Uncorrectable Errors102630
HEC Errors1116851013
OCD Errors8200
LCD Errors8200
Total Cells23000379970
Data Cells13342028580
Bit Errors00
Total ES10450
Total SES340
Total UAS25242524
I have the target SNR set to 6 in the router settings but the SNR stays at around 15 despite this setting, when I had my line installed I had a lot of issues which turned out to be a damaged cable which BT repaired, the wholesale diagnostocs speed test show:
Download speedachieved during the test was - 2.41 Mbps
 For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
 Additional Information:
 Your DSL Connection Rate :3.17 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 2.5 Mbps
I had 5Mbps+ before the line issues, how can I get my speed back up?
Thanks in advance
Andy
2 REPLIES 2
Message 2 of 3
Re: Low IP profile, high SNR
welcome to the forum
your profile is correct for your current connection speed.  the problem is your high 15db noise margin which is reducing your connection speed.  as you have 4 days stable connection the forum mods will help reset noise margin back to 6db which will incresae your speed and therefore your profile.
mods will post a contact us link
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 3/5 working days either by phone or email
Moderator
Moderator
Message 3 of 3
Hi Glebecs
Send us an email using the contact the mods link in my profile and we'll be in touch.
Stuart
