Message 11 of 15
Re: Low Ip profile - high noise margin
providing you maintain that stable connection the noise margin will continue to drop to its default 6dB and your connection speed will increase further to around 17.6Mbps
Message 12 of 15
yes the DLM will reset the connection each time the noise margin changes
russkiinbootski
Message 13 of 15
Thanks John, it was just that I felt downhearted when I saw that the connection had dropped which then changed when I saw the new line rate had changed.
russkiinbootski
Message 14 of 15
Finally appears to have settled:
Connection Information
Line state:Connected
Connection time:3 days, 21:12:03
Downstream:14.04 Mbps
Upstream:1.128 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):6.1 dB / 5.8 dB
Line attenuation (Down/Up):26.7 dB / 14.6 dB
Output power (Down/Up):20.4 dBm / 12.1 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):7253 / 26
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):11871 / 25
Error Seconds (Local/Remote):5937 / 140
Won't bore you with speed test - thanks to john46 for answering my questins and so farewell.
Moderator
Moderator
Message 15 of 15
Hi @russkiinbootski Thanks for the update and good to hear that your connection has improved.
Cheers
John
