annesley23
Message 1 of 37
MODERATOR HELP REQUIRED - Broadband continues to reduce in speed over a period of months
Hello,
Please can someone help. Ive had Bt broadband for over 4 years, for the main part of that time i have achieved a download speed of 5.5mbps. Over the past 3 months, my speed has reduced to just under 3.0mbps.
PLease find my broadband details below, i would really appreciate somebody's help on this matter as i cannot face using the phone support.
Many Thanks.
Mike Hughes
ADSL line status
Connection information
Line state Connected
Connection time 0 days, 0:04:11
Downstream 3,490 Kbps
Upstream 980 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.5
Latency type Interleaved
Noise margin (Down/Up) 6.4 dB / 5.9 dB
Line attenuation (Down/Up) 51.0 dB / 30.6 dB
Output power (Down/Up) 0.0 dBm / 12.8 dBm
Loss of Framing (Local) 0
Loss of Signal (Local) 0
Loss of Power (Local) 0
FEC Errors (Down/Up) 7101 / 4294967287
CRC Errors (Down/Up) 0 / N/A
HEC Errors (Down/Up) N/A / 0
Error Seconds (Local) 0
1. Best Effort Test:  -provides background information.
Download  Speed
3.12 Mbps
0 Mbps 4 Mbps
Max Achievable Speed
Download speedachieved during the test was - 3.12 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 3.08 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
0.83 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.83Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
36 REPLIES 36
Message 2 of 37
Re: MODERATOR HELP REQUIRED - Broadband continues to reduce in speed over a period of months
you posted almost the same thing back in november last year but never posted the further information requested
your conenction time is only 4min is that due to manual reset or hub dropping connection?
are you connected directly via a filter to the NTE5 master or test socket or to somewhere else? Is the master the only phone socket in your home?
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
Someone may then be able to offer help/assistance/suggestions to your problem
annesley23
Message 3 of 37
Hi, yes thats right. I had the ame issue back in November 2012, soon after there had been some sort of upgrade on the exchange (dont quote me on that!).
The broadband is connected to the master socket, via a filter, into the test socket.
The connection time was due to me reseting the hub, as per the instructions on the btspeedchecker page. Although i am always losing connection on a consistant basis.
I just carried out the quiet line test, with a BT cordless phone. I could hear a slight crackle all the way through. interestingly, I lost connection to the broadband when i made the phone call to 17070. This can happen quite a lot with incoming/outgoing calls.
Thanks for your reply.
Mike.
Message 4 of 37
if you can hear a crackle and you are dropping connection on incoming and outgoing calls then that sounds like a high resistence fault and you need to report a phone fault to 151 with no mention of broadband.. get that fixed and it will certainly help your broadband
annesley23
Message 5 of 37
Ok, I will give them a call now.
Many thanks.
Mike.
annesley23
Message 6 of 37
Hi,
Just spoke to the help desk (151), with no mention of broadband!!!! they have ran a line test with the phone only plugged in and then again with the broadband and phone plugged in. Both times they say there is no fault on the line.
They did say i could have an engineer out, but if the fault was found on my side they would charge me £99 or something like that. I declined the engineer when he started saying that if they found a faulty router or filter, i would be charged. I pointed out that BT had supplied these, and asked why i should be held accountable for their faulty equipment.
Please can you continue to help.
Thanks.
Mike.
Message 7 of 37
if your router is conencted to test socket with new filter then try connecting phone to filter and make a call or phone home and see if connection is still dropping
the warning about the callout charge is standard
annesley23
Message 8 of 37
Sorry, i think im a little confused. The filter is connected to the test socket, and the telephone and broadband are both plugged into the filter.
Message 9 of 37
then phone home from mobile and see if conenction drops?
Message 10 of 37
that is because the charge is raised by Openreach to BT Retail your provider and BT then pass it on this is the same with all providers
