willy456
Message 1 of 18
Massively reduced broadband speeds
So about a month ago our hub started rebooting frequently pretty much every day. Then about a week ago we noticed our broadband speed was around 4 times slower than it usually is (normally get around 3.8Mbits/s, down to around 1Mbit/s). The hub is no longer resetting all the time so I'm assuming the DLM has detected a fault somewhere and placed us on a low banded speed profile to stabilise the line.
Here are our hub stats..
Where do we start in diagnosing where the problem is? Thanks.
17 REPLIES 17
Message 2 of 18
Re: Massively reduced broadband speeds
From your stats it does look like you are in a banded profile due to your drops in connection
try quiet line test dial 17070 option 2 should be quiet and best with corded phone
can you connect to test socket with filter to eliminate your internal wiring as causing a problem. When connected to test socket check that there is no dial tone still any extension socket
ndmarston
Newbie
Message 3 of 18
How do I contact BT by email to report a drastically reduced broadband speed? I can no longer watch the sports channels I am paying for. I went through the "Chat" option, absolutely useless. No help whatsoever, unless you just want to be told to reset your Hub multiple times, with no improvement in service.
ndmarston
Newbie
Message 4 of 18
My speed has also drastically reduced. Can I contact BT by email to report this. Tried "Chat" but that was absolutely useless.
Message 5 of 18
Have you tried quiet line test? Have you tried connecting to test socket as I suggested
if you get engineer visit and it is found the problem with your connection is something internal then you will be charged £130 for engineer call out but if problem outside your home then there should be no charge.
Providing the information will help forum members help you
ndmarston
Newbie
Message 6 of 18
No I haven't. But nothing has changed. The internet was fine until a couple of days ago, then it stopped, came back on, off agin, back on, but at a reduced rate. I don't see how anything has changed from my side, no new devices, no change to anything, other than the signal. So it is something external. Anyway, not sure I have a test socket.
Message 7 of 18
You need to check quiet line test and also connect to test socket which is behind the bottom half of your master sockettest socket.jpg.
you need to make sure problem is not in your home or your wiring otherwise you will be charged the call out fee of £130. Alternatively phone 151 and report the fault and hope problem is not in your home
ndmarston
Newbie
Message 8 of 18
OK Thanks. But can I contact BT by email?
Message 9 of 18
You need to phone 151 to contact customer services but you would be better trying the checks before contacting customer services
willy456
Message 10 of 18
So I tried the quiet line test, there was some faint crackling. What would I be looking for with the test socket check?
