ktnch
Message 1 of 21
Modem keeps booting all of the wifi connetions off
For some reason our hub 3 modem keeps disconnecting all connections, happened three times in the space of two hours the other day and takes ages to reconnect any ideas ?
Been going on for a good few months now and finally got aroung to trying to isolate the problem
cheers
kev
20 REPLIES 20
ktnch
Message 2 of 21
Re: Modem keeps booting all of the wifi connetions off
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 00:32:59
Downstream:4.875 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):9.5 dB / 23.0 dB
Line attenuation (Down/Up):42.4 dB / 25.5 dB
Output power (Down/Up):19.7 dBm / 12.4 dBm
FEC Events (Down/Up):499 / 0
CRC Events (Down/Up):1 / 0
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):0 / 0
Error Seconds (Local/Remote):1 / 0
ktnch
Message 3 of 21
Time and date	Message
21:45:23, 10 May.	BLOCKED 1 more packets (because of Default policy)
21:45:23, 10 May.	IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.79]:19835 <--> [217.43.241.3]:19835 - - - [87.109.14.144]:1772 CLOSED/SYN_SENT ppp0 NAPT)
21:45:23, 10 May.	( 2373.270000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:45:21, 10 May.	BLOCKED 1 more packets (because of Default policy)
21:45:21, 10 May.	IN: BLOCK [15] Default policy (UDP [117.171.6.149]:41149->[217.43.241.3]:19835 on ppp0)
21:45:18, 10 May.	BLOCKED 1 more packets (because of Default policy)
21:45:18, 10 May.	IN: BLOCK [15] Default policy (UDP [23.118.188.175]:6881->[217.43.241.3]:19835 on ppp0)
21:45:15, 10 May.	IN: BLOCK [15] Default policy (UDP [197.237.128.218]:34919->[217.43.241.3]:19835 on ppp0)
21:45:15, 10 May.	( 2365.270000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:45:14, 10 May.	IN: BLOCK [15] Default policy (UDP [114.46.213.51]:20110->[217.43.241.3]:19835 on ppp0)
21:45:11, 10 May.	IN: BLOCK [15] Default policy (UDP [197.87.237.36]:1024->[217.43.241.3]:19835 on ppp0)
21:45:11, 10 May.	( 2361.020000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:45:10, 10 May.	IN: BLOCK [15] Default policy (UDP [157.228.89.55]:56188->[217.43.241.3]:19835 on ppp0)
21:45:09, 10 May.	BLOCKED 1 more packets (because of Default policy)
21:45:09, 10 May.	IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.79]:19835 <--> [217.43.241.3]:19835 - - - [197.87.237.36]:49267 CLOSED/SYN_SENT ppp0 NAPT)
21:45:09, 10 May.	IN: BLOCK [15] Default policy (UDP [80.92.244.71]:44204->[217.43.241.3]:19835 on ppp0)
21:45:09, 10 May.	IN: BLOCK [15] Default policy (UDP [109.205.252.224]:28192->[217.43.241.3]:19835 on ppp0)
21:45:06, 10 May.	( 2355.620000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:45:05, 10 May.	IN: BLOCK [15] Default policy (UDP [93.74.28.241]:55725->[217.43.241.3]:19835 on ppp0)
21:45:02, 10 May.	IN: BLOCK [15] Default policy (UDP [2.230.73.242]:46301->[217.43.241.3]:19835 on ppp0)
21:44:57, 10 May.	IN: BLOCK [15] Default policy (UDP [81.226.233.66]:60981->[217.43.241.3]:19835 on ppp0)
21:44:53, 10 May.	IN: BLOCK [15] Default policy (UDP [201.221.130.14]:16880->[217.43.241.3]:19835 on ppp0)
21:44:50, 10 May.	IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.79]:19835 <--> [217.43.241.3]:19835 - - - [2.219.14.29]:59012 CLOSED/SYN_SENT ppp0 NAPT)
21:44:49, 10 May.	BLOCKED 1 more packets (because of Default policy)
21:44:48, 10 May.	IN: BLOCK [15] Default policy (UDP [84.121.8.153]:24090->[217.43.241.3]:19835 on ppp0)
21:44:47, 10 May.	IN: BLOCK [15] Default policy (UDP [99.249.168.69]:59633->[217.43.241.3]:19835 on ppp0)
21:44:45, 10 May.	BLOCKED 1 more packets (because of Default policy)
21:44:45, 10 May.	( 2335.030000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:44:44, 10 May.	IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.79]:19835 <--> [217.43.241.3]:19835 - - - [84.91.28.154]:56621 CLOSED/SYN_SENT ppp0 NAPT)
21:44:44, 10 May.	IN: BLOCK [15] Default policy (UDP [1.204.14.23]:31443->[217.43.241.3]:19835 on ppp0)
21:44:40, 10 May.	( 2329.960000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:44:35, 10 May.	IN: BLOCK [15] Default policy (UDP [220.244.149.14]:26085->[217.43.241.3]:19835 on ppp0)
21:44:34, 10 May.	BLOCKED 1 more packets (because of Default policy)
21:44:34, 10 May.	IN: BLOCK [15] Default policy (UDP [112.138.104.40]:20817->[217.43.241.3]:19835 on ppp0)
21:44:32, 10 May.	IN: BLOCK [15] Default policy (UDP [85.26.233.151]:52223->[217.43.241.3]:19835 on ppp0)
21:44:31, 10 May.	IN: ACCEPT [57] Connection closed (Port Forwarding: TCP [192.168.1.79]:19835 <--> [217.43.241.3]:19835 - - - [64.229.235.130]:55538 CLOSED/SYN_SENT ppp0 NAPT)
21:44:31, 10 May.	IN: BLOCK [15] Default policy (TCP [84.122.118.52]:59574->[217.43.241.3]:64556 on ppp0)
21:44:29, 10 May.	BLOCKED 1 more packets (because of Default policy)
21:44:29, 10 May.	IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.79]:19835 <--> [217.43.241.3]:19835 - - - [70.196.69.209]:27969 CLOSED/SYN_SENT ppp0 NAPT)
21:44:29, 10 May.	IN: BLOCK [15] Default policy (UDP [181.28.233.49]:3362->[217.43.241.3]:19835 on ppp0)
21:44:27, 10 May.	BLOCKED 3 more packets (because of Default policy)
21:44:27, 10 May.	IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.79]:19835 <--> [217.43.241.3]:19835 - - - [220.244.149.14]:63815 CLOSED/SYN_SENT ppp0 NAPT)
21:44:27, 10 May.	BLOCKED 1 more packets (because of Default policy)
21:44:25, 10 May.	IN: BLOCK [15] Default policy (UDP [116.71.191.91]:41332->[217.43.241.3]:19835 on ppp0)
21:44:25, 10 May.	IN: BLOCK [15] Default policy (UDP [98.243.115.106]:43013->[217.43.241.3]:19835 on ppp0)
21:44:25, 10 May.	IN: BLOCK [15] Default policy (TCP [84.122.118.52]:59574->[217.43.241.3]:64556 on ppp0)
21:44:21, 10 May.	( 2310.890000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:44:20, 10 May.	BLOCKED 2 more packets (because of Default policy)
21:44:18, 10 May.	BLOCKED 1 more packets (because of Default policy)
21:44:18, 10 May.	IN: ACCEPT [57] Connection closed (Port Forwarding: TCP [192.168.1.79]:19835 <--> [217.43.241.3]:19835 - - - [86.153.14.62]:59407 CLOSED/SYN_SENT ppp0 NAPT)
21:44:18, 10 May.	IN: BLOCK [15] Default policy (UDP [185.18.63.85]:36096->[217.43.241.3]:19835 on ppp0)
21:44:18, 10 May.	BLOCKED 3 more packets (because of Default policy)
21:44:18, 10 May.	BLOCKED 2 more packets (because of Default policy)
21:44:18, 10 May.	IN: BLOCK [15] Default policy (UDP [178.168.15.219]:44444->[217.43.241.3]:19835 on ppp0)
21:44:15, 10 May.	IN: ACCEPT [57] Connection closed (Port Forwarding: TCP [192.168.1.79]:19835 <--> [217.43.241.3]:19835 - - - [220.244.149.14]:63646 CLOSED/SYN_SENT ppp0 NAPT)
21:44:15, 10 May.	IN: BLOCK [15] Default policy (UDP [79.182.35.224]:55059->[217.43.241.3]:19835 on ppp0)
21:44:14, 10 May.	( 2304.360000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:44:13, 10 May.	BLOCKED 1 more packets (because of Default policy)
21:44:11, 10 May.	BLOCKED 3 more packets (because of Default policy)
21:44:10, 10 May.	IN: BLOCK [15] Default policy (UDP [220.244.149.14]:26085->[217.43.241.3]:19835 on ppp0)
21:44:05, 10 May.	BLOCKED 1 more packets (because of Default policy)
21:44:05, 10 May.	( 2294.920000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:44:04, 10 May.	BLOCKED 2 more packets (because of Default policy)
21:44:04, 10 May.	IN: BLOCK [16] Remote administration (TCP [82.221.105.6]:1094->[217.43.241.3]:22 on ppp0)
21:44:04, 10 May.	IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.79]:19835 <--> [217.43.241.3]:19835 - - - [64.229.235.130]:55803 CLOSED/SYN_SENT ppp0 NAPT)
21:44:03, 10 May.	IN: BLOCK [15] Default policy (UDP [111.44.244.46]:8895->[217.43.241.3]:19835 on ppp0)
21:44:03, 10 May.	IN: BLOCK [15] Default policy (UDP [5.65.174.180]:6881->[217.43.241.3]:19835 on ppp0)
21:44:03, 10 May.	IN: ACCEPT [57] Connection closed (Port Forwarding: TCP [192.168.1.79]:19835 <--> [217.43.241.3]:19835 - - - [86.176.183.9]:47987 CLOSED/SYN_SENT ppp0 NAPT)
21:44:03, 10 May.	IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.79]:19835 <--> [217.43.241.3]:19835 - - - [220.244.149.14]:63775 CLOSED/SYN_SENT ppp0 NAPT)
21:44:03, 10 May.	IN: BLOCK [15] Default policy (UDP [220.244.149.14]:26085->[217.43.241.3]:19835 on ppp0)
21:44:00, 10 May.	IN: BLOCK [15] Default policy (UDP [82.240.38.232]:39329->[217.43.241.3]:19835 on ppp0)
21:43:59, 10 May.	IN: BLOCK [15] Default policy (UDP [94.253.22.189]:60782->[217.43.241.3]:19835 on ppp0)
21:43:59, 10 May.	( 2289.470000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:43:58, 10 May.	BLOCKED 1 more packets (because of Default policy)
21:43:58, 10 May.	IN: BLOCK [15] Default policy (UDP [89.42.103.192]:24014->[217.43.241.3]:19835 on ppp0)
21:43:55, 10 May.	( 2284.840000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:43:54, 10 May.	BLOCKED 1 more packets (because of Default policy)
21:43:54, 10 May.	IN: ACCEPT [57] Connection closed (Port Forwarding: TCP [192.168.1.79]:19835 <--> [217.43.241.3]:19835 - - - [86.176.183.9]:47962 CLOSED/SYN_SENT ppp0 NAPT)
21:43:54, 10 May.	IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.79]:19835 <--> [217.43.241.3]:19835 - - - [31.54.3.118]:61245 CLOSED/SYN_SENT ppp0 NAPT)
21:43:53, 10 May.	IN: BLOCK [15] Default policy (UDP [89.42.103.192]:24014->[217.43.241.3]:19835 on ppp0)
21:43:53, 10 May.	IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.79]:19835 <--> [217.43.241.3]:19835 - - - [89.42.103.192]:49410 CLOSED/SYN_SENT ppp0 NAPT)
21:43:53, 10 May.	IN: BLOCK [15] Default policy (UDP [187.18.216.229]:31556->[217.43.241.3]:19835 on ppp0)
21:43:52, 10 May.	IN: BLOCK [15] Default policy (UDP [177.205.40.208]:33915->[217.43.241.3]:19835 on ppp0)
21:43:51, 10 May.	IN: BLOCK [15] Default policy (UDP [128.72.73.241]:63885->[217.43.241.3]:19835 on ppp0)
21:43:47, 10 May.	IN: ACCEPT [57] Connection closed (Port Forwarding: TCP [192.168.1.79]:19835 <--> [217.43.241.3]:19835 - - - [220.244.149.14]:63605 CLOSED/SYN_SENT ppp0 NAPT)
21:43:46, 10 May.	IN: BLOCK [15] Default policy (UDP [114.80.245.44]:20206->[217.43.241.3]:19835 on ppp0)
21:43:45, 10 May.	IN: BLOCK [15] Default policy (UDP [218.188.251.187]:17439->[217.43.241.3]:19835 on ppp0)
21:43:44, 10 May.	IN: BLOCK [15] Default policy (UDP [89.216.26.234]:2631->[217.43.241.3]:19835 on ppp0)
21:43:43, 10 May.	IN: BLOCK [15] Default policy (UDP [201.3.203.207]:61599->[217.43.241.3]:19835 on ppp0)
21:43:41, 10 May.	BLOCKED 1 more packets (because of Default policy)
21:43:40, 10 May.	BLOCKED 2 more packets (because of Default policy)
21:43:38, 10 May.	BLOCKED 1 more packets (because of Default policy)
21:43:36, 10 May.	BLOCKED 3 more packets (because of Default policy)
21:43:35, 10 May.	BLOCKED 4 more packets (because of Default policy)
21:43:35, 10 May.	IN: BLOCK [15] Default policy (UDP [91.82.190.130]:23124->[217.43.241.3]:19835 on ppp0)
21:43:34, 10 May.	IN: ACCEPT [57] Connection closed (Port Forwarding: TCP [192.168.1.79]:19835 <--> [217.43.241.3]:19835 - - - [5.68.190.180]:50987 CLOSED/SYN_SENT ppp0 NAPT)
21:43:34, 10 May.	IN: ACCEPT [57] Connection closed (Port Forwarding: TCP [192.168.1.79]:19835 <--> [217.43.241.3]:19835 - - - [86.14.148.233]:53466 CLOSED/SYN_SENT ppp0 NAPT)
21:43:34, 10 May.	IN: BLOCK [15] Default policy (UDP [201.3.203.207]:61599->[217.43.241.3]:19835 on ppp0)
21:43:34, 10 May.	IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.79]:19835 <--> [217.43.241.3]:19835 - - - [201.3.203.207]:62188 CLOSED/SYN_SENT ppp0 NAPT)
21:43:34, 10 May.	IN: BLOCK [15] Default policy (UDP [89.216.26.234]:2631->[217.43.241.3]:19835 on ppp0)
ktnch
Message 4 of 21
21:43:33, 10 May.	IN: BLOCK [15] Default policy (UDP [82.1.161.192]:20911->[217.43.241.3]:19835 on ppp0)
21:43:33, 10 May.	( 2262.710000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:43:30, 10 May.	IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.79]:19835 <--> [217.43.241.3]:19835 - - - [190.4.68.174]:53102 CLOSED/SYN_SENT ppp0 NAPT)
21:43:30, 10 May.	BLOCKED 2 more packets (because of Default policy)
21:43:30, 10 May.	IN: ACCEPT [54] Connection opened (Port Forwarding: TCP [192.168.1.79]:19835 <--> [217.43.241.3]:19835 - - - [82.1.161.192]:50574 CLOSED/SYN_SENT ppp0 NAPT)
21:43:30, 10 May.	BLOCKED 1 more packets (because of Default policy)
21:43:28, 10 May.	IN: BLOCK [15] Default policy (UDP [85.94.122.179]:1161->[217.43.241.3]:19835 on ppp0)
21:43:27, 10 May.	IN: BLOCK [15] Default policy (UDP [77.34.94.211]:25785->[217.43.241.3]:19835 on ppp0)
21:43:27, 10 May.	( 2257.180000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:43:24, 10 May.	BLOCKED 1 more packets (because of Default policy)
21:43:24, 10 May.	IN: BLOCK [15] Default policy (UDP [190.4.68.174]:51413->[217.43.241.3]:19835 on ppp0)
21:43:23, 10 May.	IN: BLOCK [15] Default policy (UDP [92.237.110.39]:47923->[217.43.241.3]:19835 on ppp0)
21:43:21, 10 May.	BLOCKED 1 more packets (because of Default policy)
21:43:21, 10 May.	IN: BLOCK [15] Default policy (UDP [190.4.68.174]:51413->[217.43.241.3]:19835 on ppp0)
21:43:19, 10 May.	IN: BLOCK [15] Default policy (UDP [91.46.146.28]:22375->[217.43.241.3]:19835 on ppp0)
21:43:18, 10 May.	IN: BLOCK [15] Default policy (UDP [92.237.110.39]:47923->[217.43.241.3]:19835 on ppp0)
21:43:15, 10 May.	IN: BLOCK [15] Default policy (UDP [118.166.112.233]:16453->[217.43.241.3]:19835 on ppp0)
21:43:10, 10 May.	BLOCKED 2 more packets (because of Default policy)
21:43:09, 10 May.	BLOCKED 1 more packets (because of Default policy)
21:43:09, 10 May.	IN: BLOCK [15] Default policy (UDP [188.234.36.42]:32719->[217.43.241.3]:19835 on ppp0)
21:43:08, 10 May.	IN: BLOCK [15] Default policy (UDP [78.215.56.95]:18118->[217.43.241.3]:19835 on ppp0)
ktnch
Message 5 of 21
21:43:04, 10 May.	( 2234.400000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:43:00, 10 May.	( 2229.650000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:42:52, 10 May.	( 2222.110000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:42:47, 10 May.	( 2216.900000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:42:42, 10 May.	( 2212.290000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:42:20, 10 May.	( 2190.170000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:42:14, 10 May.	( 2184.010000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:41:51, 10 May.	( 2161.540000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:41:47, 10 May.	( 2156.710000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:41:38, 10 May.	( 2148.300000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:41:33, 10 May.	( 2142.770000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:41:28, 10 May.	( 2138.140000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:41:06, 10 May.	( 2116.320000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:41:01, 10 May.	( 2110.940000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:40:38, 10 May.	( 2088.390000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:40:33, 10 May.	( 2082.900000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:40:25, 10 May.	( 2075.170000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:40:21, 10 May.	( 2070.800000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:40:15, 10 May.	( 2065.380000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:39:55, 10 May.	( 2044.740000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:39:50, 10 May.	( 2040.130000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:39:26, 10 May.	( 2016.430000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:39:22, 10 May.	( 2011.580000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:39:14, 10 May.	( 2004.370000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:39:09, 10 May.	( 1999.380000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:39:04, 10 May.	( 1993.620000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:38:43, 10 May.	( 1972.860000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:38:38, 10 May.	( 1967.600000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:38:12, 10 May.	( 1942.340000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:38:08, 10 May.	( 1937.870000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:37:59, 10 May.	( 1929.000000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:37:55, 10 May.	( 1925.070000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:37:50, 10 May.	( 1919.980000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:37:28, 10 May.	( 1897.680000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:37:22, 10 May.	( 1892.290000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:36:59, 10 May.	( 1869.360000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:36:54, 10 May.	( 1864.420000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:36:47, 10 May.	( 1856.600000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:36:42, 10 May.	( 1852.470000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:36:37, 10 May.	( 1847.080000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:36:16, 10 May.	( 1826.050000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:36:11, 10 May.	( 1821.370000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:35:48, 10 May.	( 1798.540000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:35:44, 10 May.	( 1793.570000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:35:36, 10 May.	( 1785.690000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:35:30, 10 May.	( 1780.510000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:35:25, 10 May.	( 1775.210000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:35:04, 10 May.	( 1754.040000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:34:59, 10 May.	( 1748.680000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:34:37, 10 May.	( 1726.890000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:34:31, 10 May.	( 1721.420000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:34:23, 10 May.	( 1713.010000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:34:19, 10 May.	( 1709.250000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:34:14, 10 May.	( 1703.880000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:34:06, 10 May.	( 1696.480000) Host cctv (MAC 00:12:12:03:6a:17) using IP 192.168.1.10 detected on interface eth0, port -1
21:33:53, 10 May.	( 1683.370000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:33:49, 10 May.	( 1678.630000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:33:46, 10 May.	( 1675.780000) Lease for IP 192.168.1.81 renewed by host Kevs (MAC 34:c8:03:a8:e1:80). Lease duration: 1440 min
21:33:46, 10 May.	( 1675.780000) Device connected: Hostname: Kevs IP: 192.168.1.81 MAC: 34:c8:03:a8:e1:80 Lease time: 1440 min. Link rate: 130.0 Mbps
21:33:46, 10 May.	( 1675.610000) Lease requested
21:33:46, 10 May.	ath0: STA 34:c8:03:a8:e1:80 IEEE 802.11: Client disassociated
21:33:43, 10 May.	ath0: STA 34:c8:03:a8:e1:80 IEEE 802.11: Client associated
21:33:23, 10 May.	( 1653.110000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:33:19, 10 May.	( 1648.650000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:33:11, 10 May.	( 1641.480000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:33:07, 10 May.	( 1637.120000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:33:02, 10 May.	( 1631.870000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:32:41, 10 May.	( 1611.350000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:32:37, 10 May.	( 1606.750000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:32:15, 10 May.	( 1585.110000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:32:09, 10 May.	( 1579.370000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
ktnch
Message 6 of 21
Recorded events
21:32:02, 10 May.	( 1572.300000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:31:57, 10 May.	( 1567.400000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:31:53, 10 May.	( 1562.840000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:31:31, 10 May.	( 1540.910000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:31:25, 10 May.	( 1535.560000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:31:03, 10 May.	( 1512.910000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:30:58, 10 May.	( 1508.280000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:30:50, 10 May.	( 1500.300000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:30:46, 10 May.	( 1496.010000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:30:41, 10 May.	( 1490.750000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:30:20, 10 May.	( 1470.220000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:30:16, 10 May.	( 1465.580000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:29:52, 10 May.	( 1441.620000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:29:47, 10 May.	( 1436.840000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:29:39, 10 May.	( 1429.510000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:29:35, 10 May.	( 1424.860000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:29:29, 10 May.	( 1418.950000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:29:08, 10 May.	( 1398.270000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:29:04, 10 May.	( 1393.630000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:28:39, 10 May.	( 1369.390000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:28:35, 10 May.	( 1364.580000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:28:27, 10 May.	( 1356.980000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:28:22, 10 May.	( 1352.110000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:28:00, 10 May.	( 1329.850000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:27:37, 10 May.	( 1307.240000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:27:32, 10 May.	( 1302.200000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:27:24, 10 May.	( 1293.780000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:27:20, 10 May.	( 1289.880000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:27:15, 10 May.	( 1284.570000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:26:54, 10 May.	( 1263.980000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:26:49, 10 May.	( 1259.300000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:26:23, 10 May.	( 1232.860000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:26:18, 10 May.	( 1228.210000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:26:10, 10 May.	( 1220.540000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:26:06, 10 May.	( 1216.260000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:26:01, 10 May.	( 1211.040000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:25:54, 10 May.	( 1204.470000) Host cctv (MAC 00:12:12:03:6a:17) using IP 192.168.1.10 detected on interface eth0, port -1
21:25:37, 10 May.	( 1187.070000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:25:29, 10 May.	( 1178.580000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:25:23, 10 May.	( 1172.750000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:25:18, 10 May.	( 1167.820000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:24:55, 10 May.	( 1145.190000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:24:48, 10 May.	( 1138.300000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:24:26, 10 May.	( 1116.100000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:24:21, 10 May.	( 1110.640000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:24:13, 10 May.	( 1102.930000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:24:07, 10 May.	( 1097.000000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:24:02, 10 May.	( 1091.810000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:23:33, 10 May.	( 1062.900000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10
21:23:24, 10 May.	( 1053.940000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:23:19, 10 May.	( 1048.720000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10
21:19:32, 10 May.	( 821.910000) Host cctv (MAC 00:12:12:03:6a:17) using IP 192.168.1.10 detected on interface eth0, port -1
21:14:18, 10 May.	( 507.940000) Admin login successful by 192.168.1.71 on HTTP
21:13:57, 10 May.	( 487.380000) New GUI session from IP 192.168.1.71
21:13:25, 10 May.	( 455.000000) Lease for IP 192.168.1.83 renewed by host lumia720 (MAC b0:35:8d:8c:9c:5e). Lease duration: 1440 min
21:13:25, 10 May.	( 455.000000) Device connected: Hostname: lumia720 IP: 192.168.1.83 MAC: b0:35:8d:8c:9c:5e Lease time: 1440 min. Link rate: 65.0 Mbps
21:13:25, 10 May.	( 454.860000) Lease requested
21:13:21, 10 May.	( 451.360000) Device disconnected: Hostname: sky IP: 192.168.1.64 MAC: 00:22:d3:03:0a:db
21:13:21, 10 May.	( 451.150000) Lease for IP 192.168.1.71 renewed by host Kev LAPPY (MAC e8:03:9a:fa:9e:3f). Lease duration: 1440 min
21:13:21, 10 May.	( 451.150000) Device connected: Hostname: Kev LAPPY IP: 192.168.1.71 MAC: e8:03:9a:fa:9e:3f Lease time: 1440 min. Link rate: 72.2 Mbps
21:13:21, 10 May.	( 451.060000) Lease requested
21:13:19, 10 May.	( 449.410000) Lease for IP 192.168.1.83 renewed by host lumia720 (MAC b0:35:8d:8c:9c:5e). Lease duration: 2 min
21:13:19, 10 May.	( 449.400000) Lease requested
21:13:18, 10 May.	( 448.300000) Lease for IP 192.168.1.83 renewed by host lumia720 (MAC b0:35:8d:8c:9c:5e). Lease duration: 2 min
21:13:18, 10 May.	( 448.290000) Lease requested
21:13:15, 10 May.	ath0: STA b0:35:8d:8c:9c:5e IEEE 802.11: Client associated
21:13:11, 10 May.	ath0: STA 34:c8:03:a8:e1:80 IEEE 802.11: Client disassociated
21:13:06, 10 May.	ath0: STA 34:c8:03:a8:e1:80 IEEE 802.11: Client associated
21:13:03, 10 May.	ath0: STA e8:03:9a:fa:9e:3f IEEE 802.11: Client associated
21:12:50, 10 May.	( 420.060000) Lease for IP 192.168.1.79 renewed by host Media (MAC 48:02:2a:fb:7f:04). Lease duration: 1440 min
21:12:50, 10 May.	( 420.060000) Device connected: Hostname: Media IP: 192.168.1.79 MAC: 48:02:2a:fb:7f:04 Lease time: 1440 min. Link rate: 58.5 Mbps
21:12:50, 10 May.	( 419.960000) Lease requested
21:12:49, 10 May.	ath0: STA 48:02:2a:fb:7f:04 IEEE 802.11: Client associated
21:12:17, 10 May.	( 387.130000) CWMP: session completed successfully
21:12:17, 10 May.	( 386.840000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
21:12:12, 10 May.	( 382.120000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
21:12:12, 10 May.	( 382.110000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
21:11:41, 10 May.	( 351.460000) CWMP: session closed due to error: WGET TLS error
21:11:39, 10 May.	ath0: STA e8:03:9a:fa:9e:3f IEEE 802.11: Client disassociated
21:11:39, 10 May.	( 348.560000) NTP synchronization success!
21:11:34, 10 May.	( 342.700000) NTP synchronization start
21:11:32, 10 May.	( 340.640000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
21:11:32, 10 May.	( 340.620000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
21:11:32, 10 May.	ath0: STA e8:03:9a:fa:9e:3f IEEE 802.11: Client associated
21:11:26, 10 May.	( 334.710000) PPP IPCP Receive Configuration ACK
21:11:26, 10 May.	( 334.710000) PPP IPCP Send Configuration ACK
21:11:26, 10 May.	( 334.710000) PPP IPCP Receive Configuration Request
21:11:26, 10 May.	( 334.700000) PPP IPCP Receive Configuration NAK
21:11:26, 10 May.	( 334.700000) PPP IPCP Send Configuration ACK
21:11:26, 10 May.	( 334.700000) PPP IPCP Receive Configuration Request
21:11:25, 10 May.	ath0: STA b0:35:8d:8c:9c:5e IEEE 802.11: Client disassociated
21:11:24, 10 May.	( 333.200000) PPP IPCP Send Configuration Request
21:11:24, 10 May.	( 333.200000) PPP IPCP Receive Configuration NAK
21:11:24, 10 May.	( 333.000000) PPP IPCP Send Configuration ACK
21:11:24, 10 May.	( 333.000000) PPP IPCP Receive Configuration Request
21:11:24, 10 May.	( 332.870000) PPP IPCP Send Configuration ACK
21:11:24, 10 May.	( 332.870000) PPP IPCP Receive Configuration Request
Message 7 of 21
Have you tried a factory reset of the hub. Press the recessed button on back and hold till lights flash
ktnch
Message 8 of 21
yeah done rest soft and hard, also the socket has a built in filter
Message 9 of 21
Have you done quiet line test. Dial 17070 option 2 should be quiet and best done with corded phone.  If cordless then dull hum normal
It is unlikely to be faceplate but there have been posts where faceplate was faulty and onlt discovered by connecting to test socket
ktnch
Message 10 of 21
thats the fella, line is quiet no buzzing or noise, in the log seems the modem tries to update its self every time it kicks everyhing off as it went off around 8.20pm ish
