ktnch
Message 11 of 21
Re: Modem keeps booting all of the wifi connetions off
21:12:12, 10 May.	( 382.110000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
21:11:41, 10 May.	( 351.460000) CWMP: session closed due to error: WGET TLS error
21:11:39, 10 May.	ath0: STA e8:03:9a:fa:9e:3f IEEE 802.11: Client disassociated
21:11:39, 10 May.	( 348.560000) NTP synchronization success!
21:11:34, 10 May.	( 342.700000) NTP synchronization start
21:11:32, 10 May.	( 340.640000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS
Message 12 of 21
Then try contacting CS and complain about the hub and ask for a replacement as your line is quiet from test socket
08001114567
ktnch
Message 13 of 21
Will do and a huge thank you
ktnch
Message 14 of 21
And again the **bleep** thing !
Time and date Message 21:48:37, 11 May. ( 398.650000) Lease for IP 192.168.1.80 renewed by host bev LAPPY (MAC 78:e4:00:2e:b2:9b). Lease duration: 1440 min 21:48:37, 11 May. ( 398.650000) Device connected: Hostname: bev LAPPY IP: 192.168.1.80 MAC: 78:e4:00:2e:b2:9b Lease time: 1440 min. Link rate: 104.0 Mbps 21:48:37, 11 May. ( 398.620000) Lease requested 21:48:37, 11 May. ath0: STA 78:e4:00:2e:b2:9b IEEE 802.11: Client associated 21:48:35, 11 May. ( 396.360000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10 21:48:34, 11 May. ( 395.930000) Admin login successful by 192.168.1.71 on HTTP 21:48:30, 11 May. ( 391.580000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10 21:48:26, 11 May. ( 387.400000) CWMP: session completed successfully 21:48:25, 11 May. ( 386.150000) CWMP: HTTP authentication success from https://pbthdm.bt.mo 21:48:04, 11 May. IN: BLOCK [16] Remote administration (TCP [119.39.124.170]:53337->[81.145.245.232]:22 on ppp0) 21:48:07, 11 May. ( 368.980000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10 21:48:03, 11 May. ( 364.230000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username 21:48:03, 11 May. ( 364.220000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE' 21:48:01, 11 May. ( 362.940000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10 21:48:00, 11 May. ( 361.460000) New GUI session from IP 192.168.1.71 21:47:53, 11 May. ( 354.360000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10 21:47:49, 11 May. ( 350.910000) Lease for IP 192.168.1.71 renewed by host Kev LAPPY (MAC e8:03:9a:fa:9e:3f). Lease duration: 1440 min 21:47:49, 11 May. ( 350.910000) Device connected: Hostname: Kev LAPPY IP: 192.168.1.71 MAC: e8:03:9a:fa:9e:3f Lease time: 1440 min. Link rate: 58.5 Mbps 21:47:49, 11 May. ( 350.840000) Lease requested 21:47:45, 11 May. ath0: STA e8:03:9a:fa:9e:3f IEEE 802.11: Client associated 21:47:45, 11 May. ath0: STA e8:03:9a:fa:9e:3f IEEE 802.11: Client disassociated 21:47:45, 11 May. ath0: STA 78:e4:00:2e:b2:9b IEEE 802.11: Client disassociated 21:47:45, 11 May. ath0: STA e8:03:9a:fa:9e:3f IEEE 802.11: Client associated 21:47:44, 11 May. ath0: STA 78:e4:00:2e:b2:9b IEEE 802.11: Client associated 21:47:44, 11 May. ath0: STA 78:e4:00:2e:b2:9b IEEE 802.11: Client disassociated 21:47:41, 11 May. ( 342.250000) Lease for IP 192.168.1.64 renewed by host sky (MAC 00:22:d3:03:0a:db). Lease duration: 120 min 21:47:41, 11 May. ( 342.250000) Device connected: Hostname: sky IP: 192.168.1.64 MAC: 00:22:d3:03:0a:db Lease time: 120 min. Link rate: 100.0 Mbps 21:47:40, 11 May. ( 341.730000) Lease requested 21:47:39, 11 May. ath0: STA 78:e4:00:2e:b2:9b IEEE 802.11: Client associated 21:47:39, 11 May. ath0: STA b0:35:8d:8c:9c:5e IEEE 802.11: Client disassociated 21:47:37, 11 May. ath0: STA b0:35:8d:8c:9c:5e IEEE 802.11: Client associated 21:47:36, 11 May. ath0: STA 48:02:2a:fb:7f:04 IEEE 802.11: Client disassociated 21:47:35, 11 May. ( 336.560000) Lease for IP 192.168.1.64 expired. MAC: 00:22:d3:03:0a:db, host name: sky 21:47:35, 11 May. ath0: STA 78:e4:00:2e:b2:9b IEEE 802.11: Client disassociated 21:47:31, 11 May. ( 332.010000) CWMP: session closed due to error: WGET TLS error 21:47:31, 11 May. ath0: STA 78:e4:00:2e:b2:9b IEEE 802.11: Client associated 21:47:31, 11 May. ( 332.010000) NTP synchronization success! 21:47:29, 11 May. ath0: STA 48:02:2a:fb:7f:04 IEEE 802.11: Client associated 21:47:25, 11 May. ( 326.510000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10 21:47:23, 11 May. ( 324.000000) NTP synchronization start 21:47:20, 11 May. ( 321.490000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username 21:47:20, 11 May. ( 321.470000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE' 21:47:13, 11 May. ( 313.720000) Port forwarding rule deleted via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10 21:47:13, 11 May. ath0: STA 48:02:2a:fb:7f:04 IEEE 802.11: Client disassociated 21:47:13, 11 May. ( 314.290000) PPP IPCP Receive Configuration ACK 21:47:12, 11 May. ( 313.330000) PPP IPCP Send Configuration ACK 21:47:12, 11 May. ( 313.330000) PPP IPCP Receive Configuration Request 21:47:12, 11 May. ( 312.850000) PPP IPCP Send Configuration ACK 21:47:12, 11 May. ( 312.850000) PPP IPCP Receive Configuration Request 21:47:11, 11 May. ( 312.410000) PPP IPCP Send Configuration Request 21:47:11, 11 May. ( 312.410000) PPP IPCP Receive Configuration NAK 21:47:09, 11 May. ( 309.660000) PPP IPCP Send Configuration ACK 21:47:09, 11 May. ( 309.660000) PPP IPCP Receive Configuration Request 21:47:06, 11 May. ( 307.330000) PPP IPCP Send Configuration Request 21:47:06, 11 May. ( 307.320000) WAN operating mode is DSL 21:47:06, 11 May. ( 307.320000) Last WAN operating mode was DSL 21:47:04, 11 May. ath0: STA 48:02:2a:fb:7f:04 IEEE 802.11: Client associated 21:47:04, 11 May. ( 305.260000) PPPoA is up - VPI: 0, VCI:38 21:47:04, 11 May. ( 305.240000) CHAP authentication successful 21:47:04, 11 May. ( 304.820000) CHAP Receive Challenge 21:47:04, 11 May. ( 304.820000) Starting CHAP authentication with peer 21:47:04, 11 May. ( 304.820000) PPP LCP Receive Configuration ACK 21:47:04, 11 May. ( 304.760000) PPP LCP Send Configuration Request 21:47:02, 11 May. ( 302.990000) PPP LCP Send Configuration ACK 21:47:02, 11 May. ( 302.990000) PPP LCP Receive Configuration Request 21:47:01, 11 May. ( 302.150000) CWMP: session closed due to error: No response 21:47:00, 11 May. ( 301.420000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username 21:47:00, 11 May. ( 301.400000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE' 21:47:00, 11 May. ( 301.440000) PPP LCP Send Configuration Request 21:46:40, 11 May. ( 281.200000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34599, internal ports: 34599, internal client: 192.168.1.10 21:46:40, 11 May. ath0: STA e8:03:9a:fa:9e:3f IEEE 802.11: Client disassociated 21:46:39, 11 May. ( 279.790000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10 21:46:38, 11 May. ath0: STA e8:03:9a:fa:9e:3f IEEE 802.11: Client associated 21:46:37, 11 May. ath0: STA 78:e4:00:2e:b2:9b IEEE 802.11: Client disassociated 21:46:37, 11 May. ath0: STA 78:e4:00:2e:b2:9b IEEE 802.11: Client associated 21:46:37, 11 May. ath0: STA 78:e4:00:2e:b2:9b IEEE 802.11: Client disassociated 21:46:35, 11 May. ath0: STA 78:e4:00:2e:b2:9b IEEE 802.11: Client associated 21:46:34, 11 May. ath0: STA 78:e4:00:2e:b2:9b IEEE 802.11: Client disassociated 21:46:30, 11 May. ( 270.850000) CWMP: session closed due to error: No response 21:46:23, 11 May. OUT: BLOCK [9] Packet invalid in connection (UDP [0.0.0.0]:68->[255.255.255.255]:67 on ath0) 21:46:28, 11 May. ath0: STA 78:e4:00:2e:b2:9b IEEE 802.11: Client associated 21:46:27, 11 May. ( 267.640000) PPPoA is down after 2 minutes uptime [Disconnected] 21:46:26, 11 May. ( 266.710000) CWMP: Initializing transaction for event code 4 VALUE CHANGE 21:46:24, 11 May. ( 265.160000) PPP IPCP Send Configuration Request 21:46:22, 11 May. ( 263.460000) Port forwarding rule added via UPnP/TR064. Protocol: TCP, external ports: any->34567, internal ports: 34567, internal client: 192.168.1.10 21:46:19, 11 May. ( 260.350000) PPP IPCP Send Configuration Request 21:46:19, 11 May. ( 259.830000) PPP IPCP Receive Configuration ACK 21:46:17, 11 May. BLOCKED 1 more packets (because of Advanced Filter Rule) 21:46:17, 11 May. OUT: BLOCK [44] Advanced Filter Rule (fw/policy/0/chain/fw_ath1_out/rule/0: ICMPv6 type 143 code 0 fe80:0000:0000:0000:00fe:f4ff:fe1f:7630->ff02:0000:0000:0000:0000:0000:0000:0016 on ath1) 21:46:11, 11 May. BLOCKED 1 more packets (because of Default policy) 21:46:11, 11 May. OUT: BLOCK [15] Default policy (UDP [192.168.1.97]:50124->[212.183.131.133]:123 on ppp0) 21:46:11, 11 May. ( 252.190000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username 21:46:11, 11 May. ( 252.170000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE' 21:46:11, 11 May. ( 252.600000) PPP IPCP Send Configuration ACK 21:46:11, 11 May. ( 252.600000) PPP IPCP Send Configuration Request 21:46:11, 11 May. ( 252.380000) PPP IPCP Receive Configuration Request 21:46:05, 11 May. ( 246.420000) PPP IPCP Receive Configuration ACK 21:46:04, 11 May. ath0: STA b0:35:8d:8c:9c:5e IEEE 802.11: Client disassociated 21:46:04, 11 May. ( 244.730000) PPP IPCP Receive Configuration NAK 21:46:04, 11 May. ( 244.710000) PPP IPCP Send Configuration ACK
ktnch
Message 15 of 21
ADSL Line Status
Connection Information
Line state:	Connected
Connection time:	0 days, 00:03:22
Downstream:	5 Mbps
Upstream:	448 Kbps
ADSL Settings
VPI/VCI:	0/38
Type:	PPPoA
Modulation:	G.992.1 Annex A
Latency type:	Interleaved
Noise margin (Down/Up):	9.1 dB / 23.0 dB
Line attenuation (Down/Up):	42.4 dB / 25.5 dB
Output power (Down/Up):	19.6 dBm / 12.4 dBm
FEC Events (Down/Up):	166 / 0
CRC Events (Down/Up):	1 / 0
Loss of Framing (Local/Remote):	0 / 0
Loss of Signal (Local/Remote):	0 / 0
Loss of Power (Local/Remote):	0 / 0
HEC Events (Down/Up):	0 / 0
Error Seconds (Local/Remote):	1 / 0
ktnch
Message 16 of 21
How do i get support to look at this ??
Message 17 of 21
Did you try and get a new hub from CS?
Message 18 of 21
Did you ever try the test socket just in case there is a fault with your filtered master socket?
ktnch
Message 19 of 21
yes tried the socket but still the same, not contacted them about a modem yet, had loads of trouble before and takes ages to get though and sorted out so try to stay away from them lol
Message 20 of 21
replacing the hub is first thing to eliminate and CS is the way to get a replacement if you are still in contract as it will be free - unless you have access to another router you can try
