djurgenson
Message 1 of 3
Moving from ADSL Max to ADSL2+?
Hi
I am currently connected via ADSL Max in an area where the Exchnage has recently been upgraded to BT Infinity. I am however connected to the only cabinet not in any fibre plans. A neighbour has told me that BT are now advertising up to 17Mbps for our connection.
Telephone Number XXXXXXXXXXX on Exchange WINCHBURGH is served by Cabinet 3
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 17 -- 10 to 19.5 Available -- --
WBC ADSL 2+ Annex M Up to 17 Up to 1.5 10 to 19.5 Available -- --
ADSL Max Up to 8 -- 7 to 8 Available -- --
Fixed Rate 2 -- -- Available -- --
How can I get moved to the ADSL2+ connection? It would be a great difference to my current speeds of c6Mbps.
2 REPLIES 2
Message 2 of 3
Re: Can i upgrade from ADSL Max to ADSL2+?
I have asked a forum moderator to help you they will post their contact link here
Moderator
Moderator
Message 3 of 3
Re: Moving from ADSL Max to ADSL2+?
Hi @djurgenson Welcome to the forum.
We will be happy to help you with this if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
