Mark_W
Message 1 of 12
My BT broadband has changed to TalkTalk?!
I've had BT broadband for about 7 months now.  It was a bit of a nightmare to get setup but has been ok since then.   In the last two weeks though my broadband speeds have dropped radically.   I have tried various things to improve this but to no end.  It used to be around 6MB, now I'm lucky if I get 1MB.
Browsing the Internet tonight I tried to go the National Lottery site, and found myself blocked by TalkTalk parental filter.   WTF?!   I then went to whatismyipaddress.com and it does indeed seem my broadband is now provided by TalkTalk.
What on earth is going on?  :smileysurprised:  I wouldn't be a TalkTalk customer if you paid me!   How can I get back on BT broadband?!?!?
Any help gratefully received.
11 REPLIES 11
Message 2 of 12
Re: My BT broadband has changed to TalkTalk?!
sounds like you have been slammed by TT
contact the mods or try online chat tomorrow
contact mods
can take up to 3 working days for mods to contact you
live chat http://bt.custhelp.com/app/contact/c/2902/?s_intcid=con_intban_sanda_contact_us_chat_from_forums
mcpaddy
Message 3 of 12
Firstly you need to contact both bt and talktalk to make sure this is the case
Secondly have you had a lot of calls unanswered on your answer machine as this could be either company trying to contact you, having worked for talktalk they cannot adopt your service without talking to yourself or someone in your house hold who is acting on your behalf have you had letters from talktalk as all transfers need to have the customer fully informed in accordance to offcom guidlines, how long has passed in your opinion since you noticed the change as you may be able to reverse this if it is within 28 days
thirdly if your using a homehub these will not automatically connect to talktalk as they use a different authentication system you have to have a talktalk router or a third party pre-programmed to access there services
if it turns out to ba a slam then talktalk and the person who processed the sale can be severly dealt with in accordance to offcom guidlines depening on the recording as all sales calls are recorded
Mark_W
Message 4 of 12
I've had no phone calls form BT or TalkTalk.   I am definately being filtered by a TalkTalk filtering system of some kind.   When I go to whatismyipaddress.com it clearly says that my ISP is TalkTalk now.   I have had no dealings with TalkTalk whatsoever.   I work in a senior role in IT as my profession so I know I'm not doing anything stupid! 😉
Mark_W
Message 5 of 12
Oh and I am using a Homehub!
mcpaddy
Message 6 of 12
ah ok well thats a new one bt homehubs are pre-programed for bthomehub@btbroadband.com this detects the bt broadband service and should not work through a talktalk service
Mark_W
Message 7 of 12
I agree.   Must be some kind of routing issue maybe?   My ISP location is showing as being in an entirely different Exchange too.   I have contacted the mods - don't fancy explaining this to BT's Call Centre abroad ....
Message 8 of 12
The BT broadband service authenticates using your phone number I have flagged this post for Mods assistance
Distinguished Guru
Message 9 of 12
Hi.
The ISP location websites are frankly useless in the UK, they are incorrect with regard dynamic IP addresses in ISPs.
Are you connecting via wireless rather than ethernet ?
Is it possible you've picked up an open TT wireless connection, rather than using your own ?
Mark_W
Message 10 of 12
Ok, the plot thickens, but I now don't think this is a BT issue.   I have a homeplug system connecting my upstairs with my downstairs so that the Xbox etc can connect.   I just noticed my DG being 192.168.1.1 instead of the BT one which should be 192.168.1.254.   On unplugging the homeplug I'm now back to happily being on BT Broadband.
This is so strange.   On wired or wireless connections (using the BT secured Wi-Fi settings) I was picking up DHCP from a TalkTalk router on 192.168.1.1.   There's no such IP address on my network now that I have switched off the homeplugs.
I'm now suspecting this means my mains wiring might be suspect (this is a newly built house).   :smileysad:
