Message 11 of 12
Re: My BT broadband has changed to TalkTalk?!
that sounds  very possible  your low speeds could also be related  to poor internal wiring of extensions  you could try connecting your home hub to the test socket Test Socket.jpg
and see if your  connection speed improves
Mark_W
Message 12 of 12
I found this link which sounds exactly like my issue: http://www.avforums.com/forums/bt/1541427-bt-infinity-powerline-homeplugs.html. I may try encrypting the home plug system tomorrow. Must go to sleep now! Anyway thanks all, and it doesn't seem to be a BT issue!!
