Message 1 of 2
My wireless printer won't work anymore!
I've just had BT Infinity installed and now my wireless printer,which worked perfectly before and still does when attached to my computer, now doesn't.  I've tried un-installing it and re-installing it, spent HOURS on the phone to the help desk (please don't ask me to phone them again).  I've made sure the printer is switched on and attached to an ethernet port on the back of the hub but all it says it that it can't find the printer.  I'M TEARING MY HAIR OUT!!!!!!!!   HELP!!!!!!!!
Distinguished Guru
Message 2 of 2
Re: My wireless printer won't work anymore!
I suggest you check the properties of the printer in control panel and make sure the IP of the port matches what the IP address is allocated to printer by the hub, sounds like a miss match somewhere
(If I have helped you in any way to say "Thank You" please click on the star next to the message. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
