Spooks136
Message 1 of 6
Need my upload speed pushed back up!
Hello.
I have posted on the forum before and i am back searching for help, urgently.
I am running a ADSL2+ Connection but because of how far i am from the exchange, speeds are not as fast as they could be, nevertheless we usually run around 9-10Mbps download with around 1Mbps upload.
The upload speed has been pushed down to around 0.7Mbps and this is a problem due to the fact i have recently been livestreaming a lot on twitch.tv, 1Mbps is not enough but i make do, 0.7 is too slow.
I am supposed to be streaming today at around 7PM and i need my upload speed pushed up again, i would love to get the Annex M Service but BT only offer it to business properties.
Is there anything anyone can do to help get my upload speed pushed back up to its usual speed? If not i will need to cancel the stream which i do not really want to do.
Thank you for your time.
5 REPLIES 5
Message 2 of 6
Re: Need my upload speed pushed back up!
there is nothing that can be done to push your upload speed any higher however from my experience it does fluctuate and at the next reset you may well find that the upstream speed goes back to nearer 1mb.  there is no manual intervantion that will be done to improve it
Spooks136
Message 3 of 6
Well if that is not possible, would DSL Bonding be a good idea? I know it is expensive and BT don't offer the service but seeing as we are using our ADSL2+ connection do death, would it be worth the upgrade?
Message 4 of 6
here is an article which may help - not sure who provides the service  is there no sign of FTTC in near future? http://www.increasebroadbandspeed.co.uk/adsl-bonding
Spooks136
Message 5 of 6
We have been waiting for about 5 years for the FTTC service that was promised. After a while we understood Fibre is likely not going to happen, I did get in contact with Openreach and they said there were no plans on upgrading our cabinet. The reason why not was never provided.
Thanks for the article, i will look into ADSL Bonding. If we get 8Mbps on 1 line 2 lines should reach speeds of around 12-16Mbps. If not 3 lines will.
dfenceman
Expert
Message 6 of 6
Hi Spooks136,
If you navigated onwards from imjolly's link you may well have found this but, if not, here is a direct link :-
http://www.increasebroadbandspeed.co.uk/2014/bonding-three-four-ADSL-connections
Best regards,
dfenceman
