blaze9990
Message 1 of 10
New Bt hub, broadband flashing orange...
I just got the BT hub, but unfortunately it doesn't work. The broadband light flashes orange and the internet on the PC doesn't work. I did everything that BT says to do, but to no avail. I even pressed the wireless button and this makes the broadband light turn blue, but the wireless light flash orange. I need urgent help as I've got homework to hand in tomorrow!
Tags (1)
Message 2 of 10
Re: New Bt hub, broadband flashing orange...
is this a new bt broadband connection or existing bt connection with a new hub?
Message 3 of 10
how long have you had BT broadband?
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
blaze9990
Message 4 of 10
I just got it today, at about 12 and no I used to have sky
Message 5 of 10
when is the activation day - today?
Message 6 of 10
Is it due to go active today? Engineers might not have jumpered it in the exchange (although I would have thought by this time they have). Flashing orange means that there's no sync (connection with the exchange). I'm assuming you don't still have your sky router plugged in?
hippey
Expert
Message 7 of 10
SOunds like the service isn't active yet, it can be upto late night, but normally seems to be done by early evening. You will need to wait until after the activation date to chase up as you will get the standard reply from tech support should you try now.
Message 8 of 10
Your bt broad band can be activated any time up until midnight on your day of activation it look's like you are still with sky all you can do is wait and keep trying
Try a Search
blaze9990
Message 9 of 10
No I don't have the sky modem in, I just called BT and they said it might work tomorrow.
Message 10 of 10
what is your activation date ?
Try a Search
