tbh
Message 1 of 30
New Connection (to a new build) Capped on ADSLMax?
Hello,
Why is my new BT connection capped to 8Mbps i.e on ADSLMax? My line can quite clearly benefit from ADSL2+? (Yes the exchange is 21cn). How can I get this sorted out so im on ADSL2+, stats below (being connected for over 7 days)
6. Data rate:448 / 8128
7. Maximum data rate:1140 / 8128
8. Noise margin:25.0 / 14.6
9. Line attenuation:14.0 / 24.9
10. Signal attenuation:14.0 / 24.4
25. Modulation:          G.992.1 Annex A
26. Latency type:Fast
Thanks,
29 REPLIES 29
Message 2 of 30
Re: New Connection (to a new build) Capped on ADSLMax?
sorry but can you enter phone number and post results  remember to delete number  https://www.btwholesale.com/includes/adsl/main.html
tbh
Message 3 of 30
Hello, thanks for the quick reply here are the details:
Telephone Number ########### on Exchange HERTFORD is served by Cabinet 55
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
WBC Fixed Rate 1 -- -- Available
Other Offerings
Fibre Multicast -- -- -- Available
Copper Multicast -- -- -- Available
For all ADSL and WBC Fibre to the Cabinet (FTTC) services, the stable line rate will be determined during the first 10 days of service usage.
This line does not have left in jumpers.
Throughput/download speeds will be less than line rates and can be affected by a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for Datastream is from 30-Jun-2012; the Formal Retirement date for Datastream is from 30-Jun-2014. The Stop Sale date for IPstream is from 31-Dec-2012; the Formal Retirement date for IPstream is from 30-Jun-2014.
If the End User wishes to migrate from their current Broadband supplier they will need to contact them in the first instance to obtain a MAC (Migrations Authorisation) Code, and then contact their new Broadband supplier to arrange for the service to be migrated.
Note: Please note that postcode and address check results are indicative only. Most accurate results can be obtained from a telephone number check.
Thank you for your interest.
Message 4 of 30
can you please retry the checker again as the checker does not even show adslmax available
tbh
Message 5 of 30
Hi,
Tried it again and got the same result! I am also having issues with myBT account page where I cannot see any of the details about my account or activate BT Sport! I rang the call centre about the latter issue who after an hour decided they will need to look into it over the next couple of days!
Still regarding the broadband what can i do to get it sorted out!
Message 6 of 30
what is your post code?
tbh
Message 7 of 30
Hi,
I'll send it via a PM if thats ok.
Thanks,
Message 8 of 30
ok
Message 9 of 30
from what I can see cab 55 at SG13 7FZ is adsl2 enabled but also FTTC enabled  your new post code maybe what is causing the checker a problem
tbh
Message 10 of 30
Hi,
Thanks for the reply, the cab 55 isn't actually FTTC enabled however the old one next to it is (acording to the Openreach man)! I have suspected the new post code is causing issues with the checker, which i suspect is why I am capped to 8Mbps! How can I get this changed to ADSL2+?
