hillsjf
Message 1 of 13
New Line Installed - Promised 10MB on getting 4MB
I had a brand new line installed two weeks ago and in the order was promised 8-10mb, on a wired connection the max I can get in 4mb but normally lower even when only hub is connected on the  line (still with filter provided by BT).
Here's my home hub stats.
Please help?
     1. Product Name: HomeHub42. Serial number:  3. Firmware version: v0.07.00.1729-BT (Type B) Last updated [Unknown]4. Board version: 01A5. DSL uptime: 1 days, 06:11:256. Data Rate: 448 / 81287. Maximum Data Rate: 1304 / 90408. Noise Margin: 29.0 / 9.39. Line Attenuation: 9.5 / 12.010. Signal Attenuation: 0.0 / 12.011. Data sent/received: 67.5 MB / 602.9 MB12. Broadband username: bthomehub@btbroadband.com13. BT Wi-fi: No14. 2.4GHz wireless network/SSID:  15. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))16. 2.4GHz wireless security: WPA & WPA2 (Recommended)17. 2.4GHz wireless channel: Automatic (Smart Wireless)18. 5GHz wireless network/SSID: BTHub4-Z3QN19. 5GHz wireless connections: Enabled (802.11 n (up to 300 Mb/s))20. 5GHz wireless security: WPA2 Only21. 5GHz wireless channel: Automatic (Smart Wireless)22. Firewall: Default23. MAC Address:  24. VPI/VCI: 0/3825. Modulation: G.992.1(DMT)26. Latency type: Fast27. Software variant: -28. Boot loader: 0.4.3-BT (Mon Jun 9 14:23:56 2014)
12 REPLIES 12
Message 2 of 13
Re: New Line Installed - Promised 10MB on getting 4MB
You are on adslmax with max connection speed 8 mb. If adsl2 available then mods may help get changed
can you enter phone number and post results. Remember to delete number. https://www.btwholesale.com/includes/adsl/main.html
hillsjf
Message 3 of 13
I can see I'm on ASDL Max, with a max speed of 8mb as quoted in my BT order, but I'm still getting only half this speed.
Message 4 of 13
can you please post the result of the checker as asked by imjolly
hillsjf
Message 5 of 13
It's a download speed on a wired connection of 4.2mb and upload of 0.2mb
hillsjf
Message 6 of 13
BT BROADBAND AVAILABILITY CHECKER
Telephone Number xxx xxx xxxx on Exchange HURST GREEN is served by Cabinet 3
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
ADSL Max Up to 8 -- 7 to 8 Available
Fixed Rate 2 -- -- Available
Message 7 of 13
as you can see from the checker your exchange has not been upgraded to 21CN hence adsl2 is not avialable
Message 8 of 13
I have reformatted your stats to make it easier to read
2. Serial number:
13. BT Wi-fi: No
23. MAC Address:
24. VPI/VCI: 0/38
Message 9 of 13
can you now run btspeedtester and when first test completes then run diagnostic test and post results please
do not reset before test and use wired connection
btspeedtester
hillsjf
Message 10 of 13
I've run the btspeedtester and then run diagnostic test and got the following results:
Download speedachieved during the test was - 2.07 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 7.15 Mbps
