Diwali
Message 1 of 8
New broadband installation
I’m planning to install broadband soon. The incoming copper line terminates in a 60 year old terminal box. I do not have a modern master box, just a basic one supplied by BT about 15 years ago and supplied from the 60 year old terminal.
Can broadband be installed with my existing equipment or do I need an upgrade? If the latter, will it be included in the installation package or will I be expected to pay the extra.
7 REPLIES 7
imjolly
Message 2 of 8
Re: New broadband installation
As long as there is no line noise on phone then broadband will work with existing socket using filter
Diwali
Message 3 of 8
Thanks. My line is due to be repaired tomorrow so I can check for noise then.
Diwali
Message 4 of 8
The line was repaired and terminal and box sorted. Brilliant job by the engineer working in compliance with Covid restrictions.
Broadband installed a few days later by BT and all good.
BT/Openreach have been impressive from the start.  Kudos to them.
Keith_Beddoe
Message 5 of 8
@Diwali
Do you want to provide feedback to Openreach?
P.S. Its just Openreach, not BT Openreach.
Diwali
Message 6 of 8
Yes. I’d like to give positive feedback when it’s deserved. Thanks.
D
Diwali
Message 7 of 8
Where’s the button to click? I don’t see it!
“If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted Solution’.”
Keith_Beddoe
Message 8 of 8
D
You can give feedback on this form.
https://www.openreach.com/thank-an-engineer-form
It is appreciated.
