Message 1 of 5
New btwholesale Speedtest.
The New bt speed test diagnostic window is too quick to read the Results before it closes , yet the First Test window stays open with the Results until it's cancelled, or I move on to the Diagnostic test using  my phone number , I'm using Windows Vista and a google browser that won't update any more ,  any one help ?
4 REPLIES 4
Message 2 of 5
Re: New btwholesale Speedtest.
Have you tried using a different browser?  Maybe try IE
Anonymous
Not applicable
Message 3 of 5
I don't know if it will solve your problem or not but you could try Opera, it's probably a better choice than Chrome for W7.
Message 4 of 5
Yes I have,  ie opens the page then does nothing , Firefox opens then does both Tests perfectly well, Opera does first test , but doesn't do the diagnostic test .
Message 5 of 5
Thanks , I also use thinkbroadband speed test and Ookla , so no big deal that Chrome only does half the test, thank you !!
