lewispeano
Newbie
Message 1 of 6
New build property
So I have just moved into a new build property. BT openreach has just connected my house to the green box - copper broadband - on the estate. Also, the postcode isnt recognised on most sites.
I want to test the speed before I commit to buying broadband from a provider. I have a CAT5e cable, can I plug that into the master socket and a laptop and connect to the internet and test on Ookla or something like that?
Really appreciate the help, not so good with things like this
5 REPLIES 5
Message 2 of 6
Re: New build property
no you cannot run an internet speed test unless the line is activated
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
lewispeano
Newbie
Message 3 of 6
I dont have a landline number either yet. I put my address in to the same site and it came up with this. Screen Shot 2017-06-30 at 19.28.37.png
Message 4 of 6
Unless you have ordered broadband/phone from a supplier you are not connected to anything.
If you were to order Infinity1 you could expect speeds of 45-50Mbps
lewispeano
Newbie
Message 5 of 6
Is infinity1 fibre?  The Openreach person said we don't have fibre where we live unfortunately
Message 6 of 6
Yes and yes you do, that is what the checker shows.
You have FTTC (fibre to the cabinet) aka VDSL available to you.
