Pete56
Message 1 of 12
New contract speed issue
I saw somewhere on this forum that BT always connect customers at the highest possible speed, I've recently returned to BT after a year with Plusnet (really good offer), when I left BT I was getting 12.5 Mbps download, these are the hub stats from 2015 with BT
28/06/2015
ADSL Line Status
Connection Information
Line state:
Connected
Connection time:
0 days, 20:23:20
Downstream:
12.58 Mbps
Upstream:
1.118 Mbps
ADSL Settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.5 Annex A
Latency type:
Interleaved
Noise margin (Down/Up):
3.1 dB / 5.7 dB
Line attenuation (Down/Up):
33.9 dB / 18.5 dB
Output power (Down/Up):
20.4 dBm / 12.4 dBm
FEC Events (Down/Up):
15830310 / 109
CRC Events (Down/Up):
2755 / 42
Loss of Framing (Local/Remote):
0 / 0
Loss of Signal (Local/Remote):
0 / 0
Loss of Power (Local/Remote):
0 / 0
HEC Events (Down/Up):
24660 / 13
Error Seconds (Local/Remote):
380 / 7
These are the stats with Plusnet
18/09/2015
ADSL Line Status
Line state:
Connected
Connection time:
3 days, 06:18:49
Downstream:
11.18 Mbps
Upstream:
1.168 Mbps
ADSL Settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.5 Annex A
Latency type:
Fast
5.4 dB / 5.8 dB
33.8 dB / 18.6 dB
20.6 dBm / 12.7 dBm
0 / 0
7545 / 236
0 / 0
0 / 0
0 / 0
19214 / 246
4625 / 131
These are the current stats with new BT contract
ADSL Line Status
Line state:
Connected
Connection time:
0 days, 01:33:52
Downstream:
7.875 Mbps
Upstream:
448 Kbps
ADSL Settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.1 Annex A
Latency type:
Interleaved
15.7 dB / 29.0 dB
34.4 dB / 19.5 dB
20.0 dBm / 10.6 dBm
346 / 0
14 / 0
0 / 0
0 / 0
0 / 0
124 / 0
8 / 0
From BT Wholesale speedtest
Download 6.95
Upload 0.37
Ping 52.63
Will the speed improve or am I stuck on ADSL Max, nothing has changed from the router to the exchange so I would be expecting to be getting near to the same speed as before.
11 REPLIES 11
Moderator
Moderator
Message 2 of 12
Re: New contract speed issue
Hi @Pete56,
It does look like your connection is still on ADSL max. I'll be able to take a look at this for you. Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
Pete56
Message 3 of 12
I filled in and sent the form 'Contact the Mods' on 13 Sept, I got the auto email response and an incident number, since then nothing, any ideas ?
Message 4 of 12
if you have contacted PaddyB please now leave it in his hands now as the forum mods take personal ownership of problems and provide a single point of contact in the UK at the moment once you contact them they are taking 5+ working days to reply to your personally by phone or email they have a very good success rate with problems
Pete56
Message 5 of 12
OK thanks for that.
Pete56
Message 6 of 12
I'm not getting anywhere with this at the moment, I've just received an email from BTCare saying that the line is connected to ADSL2+ and that I'm getting more than 8Mbps DL and so there's nothing they can do,
24/09/2016
ADSL Line Status
Line state:
Connected
Connection time:
1 days, 21:49:50
Downstream:
7.875 Mbps
Upstream:
448 Kbps
ADSL Settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.1 Annex A
Latency type:
Interleaved
15.0 dB / 28.0 dB
34.4 dB / 19.5 dB
20.0 dBm / 10.6 dBm
6984 / 12
230 / 2
0 / 0
0 / 0
0 / 0
2394 / 0
355 / 11
BT Wholesale Speed Test 24/09/2016
DL 6.93Mbps
UL 0.36Mbps
Ping 84ms
I've run out of ideas, unless I'm missing something, Modulation G992.1as indicated on the hub is ADSLmax, so I'm not on ADSL2, I can only give the information available from my end, there's obviously no point in me continually replying to their email telling them the information and them replying telling me something else, any ideas ?
Message 7 of 12
That e-mail would not be from the moderators.
It looks like you have been re-contracted onto ADSL Max by mistake.
To could copy the details to BT Care, but I expect you will have to wait for the moderator.
Moderator
Moderator
Message 8 of 12
Hi @Pete56 Sorry you are not happy with the response you have received. I have checked and the reply is to your forum email so if you remain unhappy you should reply to your case handler.
cheers
John
Community ModeratorJohnC
Kudos”Kudos”
Pete56
Message 9 of 12
OK thanks
Just to be sure, can you confirm that if the HH3 reports G.992.1 then the line is on ADSL max, or in other words G.992.1 is ADSL max and G.992.5 is ADSL2
Regards
Message 10 of 12
992.1 is adslmax and 992.3/993.5 is adsl2/2+
your stats are showing max speed connection for adslmax
