Message 101 of 117
Re: NOT A HAPPY BUNNY!!!
can you post current stats to see change please
Jaspero
Message 102 of 117
Yes i will do guyz, after I speak with Olga my Mod for this 🙂
Message 103 of 117
thanks looking forward to positive outcomeSmiley Wink
Jaspero
Message 104 of 117
Ok, time to give this bad boy a go.....see If things have improved, whats the bt whole link again?
Message 105 of 117
btspeedtester
Jaspero
Message 106 of 117
1. Best Effort Test: -provides background information.
Download Speed
2.46 Mbps
0 Mbps 4 Mbps
Max Achievable Speed
Download speedachieved during the test was - 2.46 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 2.51 Mbps
2. Upstream Test: -provides background information.
Upload Speed
0.36 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.36Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
Jaspero
Message 107 of 117
thank you BT!!!!!
Jaspero
Message 108 of 117
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 0 days, 03:51:56
Downstream: 2.781 Mbps
Upstream: 448 Kbps
Jaspero
Message 109 of 117
11:46:39, 09 May. (105514.650000) ETHoA is up -​ VPI: 0, VCI:35
11:46:39, 09 May. (105514.650000) DSL is up
11:46:38, 09 May. (105513.100000) DSL noise margin: 19.00 dB upstream, 6.00 dB downstream
11:46:38, 09 May. (105513.030000) DSL line rate: 448 Kbps upstream, 2848 Kbps downstream
tHEY DID IT WOW!!!! FANTASTIC WORK!
Jaspero
Message 110 of 117
The Engineer said it never could be done.....and stable well it is down to 6db, over the moon!!! Thank you to my Mod and the BT Team hope it stays this way 🙂
