Jaspero
Message 11 of 117
Re: Noise Margin + Capped a 2MBsec
WBC ADSL 2+ Up to 2 -- 1.5 to 3 Available
ADSL Max Up to 2 -- 1 to 3 Available
WBC Fixed Rate 2 -- -- Available
Jaspero
Message 12 of 117
does this help?
Message 13 of 117
just confirms that expected is about 2mb but with the stats you posted I expect 3/3.5mb once noise margin reduced
Jaspero
Message 14 of 117
no change overnight im afraid.....any further i can but wait 3 dayz
Message 15 of 117
just a matter of staying connected 24/7 and repost your stats showing the 3 days connection and then getting mod help to reset noise margin back to 6db which will increase your current connection speed
Jaspero
Message 16 of 117
Been 3 days now! Can you get my DB reset plz??
Jaspero
Message 17 of 117
I mean my Noise Margin
ADSL Line Status
Connection Information
Line state:Connected
Connection time:3 days, 03:07:43
Downstream:1.938 Mbps
Upstream:448 Kbps
Message 18 of 117
can you post the 2 lines of stats showing connection speed and noise margin please
Jaspero
Message 19 of 117
08:40:15, 28 Apr. (46704.580000) DSL noise margin: 19.00 dB upstream, 12.10 dB downstream
08:40:14, 28 Apr. (46704.510000) DSL line rate: 448 Kbps upstream, 1984 Kbps downstream
Message 20 of 117
thanks
mods will post link
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 3/5 working days either by phone or email
