Jaspero
Message 21 of 117
Re: Noise Margin + Capped a 2MBsec
the mods will post link on this page for me??? another 3/5 dayz, geez 😞
Message 22 of 117
yes they will post and then you will be able to see the contact us link as in my post  it may not take that long but you are joining a queue of others waiting for mod help
Jaspero
Message 23 of 117
ok thank you for all your help, the waiting game begins again 😞
Message 24 of 117
mods will post link shortly just keep checking
Jaspero
Message 25 of 117
Thank you Jolly, ur the best!
Moderator
Moderator
Message 26 of 117
Hi Jaspero,
I'll be able to take a look at your connection. Please send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
Jaspero
Message 27 of 117
did you get my email ok Paddy?
Message 28 of 117
did you note the ref number which appeared after to sent the email?
Jaspero
Message 29 of 117
Yup
Jaspero
Message 30 of 117
I didnt with the first email sent as I thought id get an email through with it, but heres the 2nd one
140501-*****
