Message 31 of 117
Re: Noise Margin + Capped a 2MBsec
that's ok but delete the ref for your security as this is a public forum
Jaspero
Message 32 of 117
Paddy done it for me 🙂 Hopefully get to me soon 🙂
Message 33 of 117
at least you know mods will reset your noise margin and not just some CS agent in India.  can you post the 2 lines of stats after noise margin reset to show improvement - good to see outcome
Jaspero
Message 34 of 117
I sure will, when will I know its reset? will it disconnect and reconnect?
Message 35 of 117
yes there will be a drop in conenction and I expect noise margin to then show 6db or thereabouts and your connection speed to have increased.  as you are on adslmax hopefully the reset will also give you the correct profile for your new connection speed so you will notice faster download
Jaspero
Message 36 of 117
wonderful.... reset me, reset me.lol 🙂
Jaspero
Message 37 of 117
Can I mod please fix my reset please?
Message 38 of 117
As I said when you completed the email you joined a queue of others waiting for mod help.  It can take a few working days before mods contact you either by phone or email - just patience
Jaspero
Message 39 of 117
Yes, paddy sent me a private msg saying there was only a couple infront but he's offline now....do all the mods go offline at a certain time? lol, Patience is not my strong suit when I have a nagging pregnant wife and kid who can play his games online.....
Message 40 of 117
If there is only couple of customers before you then it should not be long before they reset the noise margin and speed increases
