Jaspero
Message 51 of 117
Re: Noise Margin + Capped a 2MBsec
My Hub restarted by itself but it has connected at the same speed and db level!?
Message 52 of 117
just leave it connected it may be the mods making changes
Jaspero
Message 53 of 117
15:22:47, 02 May.(416453.520000) DSL noise margin: 19.00 dB upstream, 12.30 dB downstream
15:22:47, 02 May.(416453.450000) DSL line rate: 448 Kbps upstream, 1952 Kbps downstream
15:20:38, 02 May.(416324.470000) DSL is down after 6160 minutes uptime
15:20:38, 02 May.(416324.470000) ETHoA is down after 6160 minutes uptime
15:20:37, 02 May.(416324.110000) PPPoA is down after 6160 minutes uptime [Waiting for Underlying Connection (WAN DSL - Up)]
15:20:33, 02 May.(416319.940000) PPP LCP Send Termination Request [User request]
08:40:20, 28 Apr.
(46709.790000) WAN operating mode is DSL
Message 54 of 117
hopefully next set of stats will show noise margin down at 6db with faster connection speedSmiley Wink
Jaspero
Message 55 of 117
will it disconnect again for that to happen Jolly?
Message 56 of 117
yes has to be a disconnection as noise margin reset which will increase your connection speed
Jaspero
Message 57 of 117
ok, I lovely lady from the Mod team called me and said she reset it to 6db, I restarted it but now its worse, do I reset the hub or reset again?
16:13:51, 02 May.( 83.500000) DSL is up
16:13:49, 02 May.( 82.060000) DSL noise margin: 18.00 dB upstream, 12.90 dB downstream
16:13:49, 02 May.( 81.900000) DSL line rate: 448 Kbps upstream, 1920 Kbps downstream
Jaspero
Message 58 of 117
Meant do I restart it again or reset the hub with the little button on the back?
Message 59 of 117
I would wait as mod would normally trigger a reset which should get noise margin back to 6db  if you keep trying a reset to see if any change you are going to drive noise margin higher and speed lower and then need mod help again  sorry but you need to be a bit more patient
Jaspero
Message 60 of 117
The mod told me to restart it though for the Noise Margin to take effect and to watch it over the next few hours, I'm terrible understanding Irish accents which she has.....I just cant remember if she said restart it or to reset it.......? It would be good in a email answer.Sorry, its my fault though....I wasnt expecting the call while trying to feed my son =/
