Sirshelley
Newbie
Message 1 of 11
Noise issue + DNS Reset request
Below is a link to a screeshot demonstring ADSL stats and uptime for my router/modem
 http://clip2net.com/s/3iwOLT1
Internet speed and noise increased roughly two weeks ago following a malfunctioning microfilter - that has subsequently been replaced.
I have read on other posts that following an unstable connection an automated BT system attenuates bandwidth in response ,reducing speed.
I have also read that after 3-5 days of a stable connection the same system will attempt to reverse these precautions in 3DB intervals. And that if this fails to take place I either have an issue with my line (which is extremely unlikely considering the circumstances) and that I should contact a forum moderator in order to process a DNS reset request.
If my research/assumptions are correct I am happy to supply any info further required.
Otherwise I appreciate any advice in advance.
-J.Shelley
P.s I have performed these same tests on the main phone connection with similar results indicating extension wiring is functioning fine.
10 REPLIES 10
Message 2 of 11
Re: Noise issue + DNS Reset request
Please delete your phone number this is a public forum viewable world wide and you are leaving your self open to scammers and nuisance callers
Message 3 of 11
you cannot get a DNS reset you mean a noise margin reset
this is your problem
Due to all the disconnections / restarts of your hub you are now in a banded profile you need to maintain a stable connection for 3/5 days and you will start to lift out of the banding automatically
http://www.plus.net/support/broadband/speed_guide/broadband_terminology.shtml
Sirshelley
Newbie
Message 4 of 11
Thanks for that one : Deleted
Sirshelley
Newbie
Message 5 of 11
Apologies for incorrect terminology. (Im an electronic engineer only specalising in chips)
As you can see my connection has an uptime of 75 hours - just over 3 days.
Message 6 of 11
Your connection time is 28 hrs so just stay connected and banding shou,d release automatically in 3/5 days. If you get 3+ days connection time then repost your stats and mods may be able to help
75hrs is system uptime which is not the same
Sirshelley
Newbie
Message 7 of 11
Ah ok that explains things ; again terminology issues it seems.
If you would be kind as to let me know what uptime is reffering to?
Message 8 of 11
connection time length of time connected to internet system up time length of time router has been powered up
Sirshelley
Newbie
Message 9 of 11
Many thanks for the info; I did perfrom a software commanded reboot during tests.
Message 10 of 11
just leave the connection alone now please
