Moderator
Moderator
Message 91 of 96
Re: Noise margin reset please
Hi @Traumatic How has the connection been over the last few days? If it has been stable are you OK for me to close this case now?
Post back and let me know.
cheers
John
Traumatic
Message 92 of 96
Hi John,
I don't honestly know. I don't think it's been resetting the line like it I used to do. But the speed is still at 7 meg and a reset 10 hours ago. What does it show you from your end?
Moderator
Moderator
Message 93 of 96
Hi @Traumatic Good to hear that the speed is around 7mb. I've tested the connection and there have been very drops in connection over the last week. Is that what you are experiencing? and if all is OK are you happy for me to close this off?
If you are still having problems just let me know.
Cheers
John
Traumatic
Message 94 of 96
Hi John,
I think at the minute it's okay, so the case can be closed.
It would be good to try and keep the notes on file, so in case it does happen again, everyone knows where the issue is
Moderator
Moderator
Message 95 of 96
Hi Traumatic
Thanks for update John is in later today I'll let him know you've repied on here so he can get back to you.
Stuart
Moderator
Moderator
Message 96 of 96
Hi @Traumatic Thanks for getting back to me and good to hear all is OK now. Hopefully the problem won't re-surface but if it does come back and let us know and we will be happy to help.
Cheers
John
